- Joined
- Oct 13, 2011
- Messages
- 9
- Reaction score
- 0
13:40:34.390 [CM503007]: Call(5164): Device joined: sip:[email protected]:5066
13:40:34.375 [CM503007]: Call(5164): Device joined: sip:[email protected]:5062
13:40:34.359 [CM505002]: Gateway:[Patton7] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Patton SN4524 JO EUI 00A0BA05057C R5.8 2011-07-01 H323 SIP FXS FXO M5T SIP Stack/4.0.30.30] PBX contact: [sip:[email protected]:5060]
13:40:34.359 [CM503002]: Call(5164): Alerting sip:[email protected]:5066
13:40:34.031 [CM503025]: Call(5164): Calling PSTNline:7809171211@(Ln.10003@Patton7)@[Dev:sip:[email protected]:5066]
13:40:33.984 [CM503005]: Call(5164): Forwarding: PSTNline:7809171211@(Ln.10005@Patton8)@[Dev:sip:[email protected]:5062,Dev:sip:[email protected]:5064,Dev:sip:[email protected]:5060,Dev:sip:[email protected]:5066]
13:40:33.984 [CM503005]: Call(5164): Forwarding: PSTNline:7809171211@(Ln.10003@Patton7)@[Dev:sip:[email protected]:5066]
13:40:33.968 [CM503016]: Call(5164): Attempt to reach <sip:[email protected]:5060> failed. Reason: Not Registered
13:40:33.968 [CM503017]: Call(5164): Target is not registered: <sip:[email protected]:5060>
13:40:33.968 [CM503016]: Call(5164): Attempt to reach <sip:[email protected]:5060> failed. Reason: Temporarily Unavailable
13:40:33.968 [CM503026]: Call(5164): Target is not available: RingAll800[]
13:40:33.953 [CM503010]: Making route(s) to <sip:[email protected]:5060>
13:40:33.937 [CM505002]: Gateway:[Patton7] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Patton SN4524 JO EUI 00A0BA05057C R5.8 2011-07-01 H323 SIP FXS FXO M5T SIP Stack/4.0.30.30] PBX contact: [sip:[email protected]:5060]
13:40:33.937 [CM503001]: Call(5164): Incoming call from anonymous@(Ln.10001@Patton7) to <sip:[email protected]:5060>
800 is our receptionist ring group. That ring group is set to ring 4 extensions for 15 seconds, then connect to extension 305 if no answer. 305 is unregistered but forwards to our after-hours call centre (the 7809171211) number. The 4 extensions were free at the time, but this call was immediately ditched by the system. This is a very intermittent problem. Any ideas?
