Taxation 3CXV12
Discussion in '3CX Phone System - General' started by amkengne, Sep 16, 2013.
  1. amkengne
    Feb 6, 2013
    how to use the option of taxation 3CXV12 server for billing calls when extensions call outward.
  2. bardissi
    bardissi Member
    Jan 31, 2012
    318
    3CX is not really built to handle taxation from the billing / reporting perspective.
  3. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    There may some 3rd party apps which can help facilitate call reporting into something else which can handle that for you.. not clear off hand "which" or "where".. but I have seen other apps which make things happen. You may be able to grab the calls from the db and perhaps integrate directly.. but none is built in for the task which you are asking about.
