TCP Connection
Discussion in 'Android' started by blastek, Aug 13, 2010.
  1. blastek
    Aug 5, 2010
    Is there a way to use TCP instead of UDP to increase battery life? A standby test was done on XDA and they found the phone only received 15 hours with UDP and 150 hours with TCP.
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    3CX does not support SIP over TCP yet. Could you point to this test, I want to see what they did.
  3. loganss
    Jul 21, 2010
    15
    Yes, please provide a link of this xDA test. I've been curious about this topic for awhile.
