TCP on Asterisk
Discussion in 'iOS' started by wstobbs, Jun 8, 2011.
  1. wstobbs
    Jun 8, 2011
    Hi Support.
    Great app on iPhone. I had some issues using it externally but have solved them by setting up a VPN. I will investigte the last of audio path externally later.
    Youhave a topic in teh tech support tht covers multi tasking, and I quote below
    You mention in the last piece about some code that I need to put in the Asterisk, but you seem to have missed of what we should be inserting. Can you give me the detail?
    Thnaks for your support on a great product
  2. StefanW
    Jun 2, 2009
    1,222
    93
    Just save your self the hassle, the code has been removed due to it was not trivial for all Asterisk version...
    Switch to a 3CX PBX for Windows and we can handle TCP by default for incoming requests and handle it accordingly
    or ask your local asterisk for further help in this case.
