TCP only SIP Trunk configuration?
Discussion in '3CX Phone System - General' started by ozetto, Apr 22, 2015.
  1. ozetto
    Apr 22, 2015
    I need to create a SIP Trunk with TCP only configuration.
    is there any way to specify transport type for generic sip trunk?
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,155
    176
    VOIP Providers - Click on Add Provider - Select Generic from the Country list
  3. ozetto
    Apr 22, 2015
    Hi Saqqara,
    Thanks for the reply but my question is how to create sip trunk with TCP transport type?
    now it works with UDP and I need to make it work with TCP.
    Thanks.
  4. Saqqara
    Mar 12, 2014
    1,155
    176
    Check out http://www.3cx.com/forums/please-help-how-to-configure-sip-trunk-with-tcp-32639.html
  5. ozetto
    Apr 22, 2015
    TCP or UDP all allowed but this is not the case because 3CX uses UDP.
    This topic ( http://www.3cx.com/forums/3cx-only-tcp-voip-provider-40294.html ) is more convenient for my situation but as it was writen in that topic, there was no solution before.
    What about now? is there any solution?
    By the way, far end SBC configured to listen the port and TCP communication works with softphones directly.
    Is there any option for SIP Trunks like server mode or client mode?
