TCP/UDP port 5060 Untangle Firewall
Discussion in '3CX Phone System - General' started by mdonner, Dec 15, 2009.
  1. mdonner
    May 23, 2009
    while setting up 3cx for my customer i ran into a problem with port 5060. i changed the port on 3cx 5061 and all the test went through. i put it back to 5060 it fails. i am using untangle firewall which is a open source software package. what do i need to do to fix this problems.
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    The question is why does it fail. It could be the firewall, it could be your ISP, it could be other things.
  3. leejor
    11,129
    330
    Either port 5060 is being blocked, by something, or, it is being used elsewhere on the network, or, at least the firewall/router thinks so.
  4. mdonner
    May 23, 2009
    the firewall is not blocking. it is not be used by anything else.
  5. leejor
    11,129
    330
    Port 5060 is being used by? Remote extensions or a VoIP provider? If it's a VoIP provider you might try provisioning an ATA and try connection it directly to the VoIP provider both behind the firewall and then on the other (outside) side using port 5060. That would, at least, tell you if it's a firewall issue or something, perhaps your ISP is doing.
