TDM-400's? PCI Cards?
Discussion in '3CX Phone System - General' started by redozbris, May 19, 2008.
  1. redozbris
    May 19, 2008
    Good Morning All,
    Quick question,
    I've got lots of little voip products at home that I've been tinkering with for years, but never actually got around to setting up a PABX as the trusted old system we've got in the office is working, but its getting long in the tooth.
    Question:
    I've got several sipura external box's (with FX0 and FXS Ports) and TDM-400's, that I would like to use with 3CX, but from what I can see it doesnt support the cards, is this correct?
    Has anyone setup 3CX with TDM-400's or am I doomed to try and use Asterisk :)
    Mark
  2. datu503
    May 17, 2008
    14
    Well the TDM400 Cards are NOT supported on 3CX :oops:
    but the sipura boxes should be easy, they are external boxes and should work perfect.
    Well nothing is lost on the TDM400, you can always have it run on asterisk and then use it as a sip trunk for 3CX.
    Just for the fun of it. But then if you have the sipura 3000, then that should be what you need for outbound inbound calls.
