Technical notes
Discussion in '3CX Phone System - General' started by Vali_3CX, Jun 29, 2009.
  1. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,531
    69
    This topic will contain technical notes about 3CX Gateway for Skype 2.0
  2. Vali_3CX
    Dec 12, 2008
    1,531
    69
    Memory and CPU usage
    There are attached few snapshots about system resources required by a 30-ports 3CX Gateway for Skype 2.0.
    - Test has been done on a notebook having installed Win XP SP2, Intel processor 1.83GHz, 2GHz RAM, no pagefile.
    - At the test time, alongside gateway a PBX 8.0 with Cassini server was running, the Outlook Express and a Media Player.
    - The memory already taken when gateway has been started was ~600MB.
    - Each gateway port (Skype + gateway) requires ~40MB (see the processes list) therefore an overall 1200MB.
    - CPU is most overloaded during gateway startup process, due to Skype client initialization. However, sequential start and multiprocessor support allowed PBX and Media Player to don't struggle with UI responding and audio quality (CPU usage average 45%, peaks of 70%)
    - Once all 30 ports were started, CPU usage become the common one, 0-4%.
    - When gateway service has been stopped, memory consumption dropped back to ~600MB.
  3. Vali_3CX
    Dec 12, 2008
    1,531
    69
    Muting gateway Skype sound
    One annoying aspects of the gateway's functionality is to hear Skype sound on the gateway machine.
    Unfortunately, there is no way to programatically mute Skype's sound, they don't provide this feature yet. Therefore, you have to mute Skype sound manually for each gateway port you created, as follows:
    When you configure each Skype client, go the Tools/Options menu, General/Audio settings page. There, on "Speakers", uncheck the "automatically adjust speakers settings" and set the slider to minimum. To mute ringing sound, set it to "Use selected speaker". Click Save. When you have done this for all Skypes, restart the gateway.
