tel: links not working correctly (Windows)
Discussion in '3CX Clients' started by BSHC, Mar 1, 2018.
  1. BSHC
    Mar 1, 2018
    After the most recent Windows Client update, "tel:" links no longer behave correctly.
    Previously, formatting of the number did not seem to matter: "tel:2027621401" worked the same as "tel: (202) 762-1401" without issue.
    After the update, the client is interpreting "tel: (202) 762-1401" as "202207621401" after clicking.
    Any ideas? Windows Client version 15.5.8801.3. Using the Chrome extension fixes the issue, but it cannot be used in this particular case.
  2. JCLloyd
    JCLloyd New Member
    Oct 5, 2017
    112
    19
    I thought I'd give this a bump... The client seems to be translating the space character into its ascii equivalent of "20", instead of stripping it out. I am fairly new to 3CX and not familiar with what you are doing, so I got myself tagged in case 3CX responds with an answer!
  3. complex1
    complex1 Active Member
    Jan 25, 2010
    752
    38
    I don’t have any issues with Windows Client version 15.5.8801.3 and dial a number like “(202) 762-1401”
    Only difference is I’m using FireFox. Maybe Chrome is causing the issue?
  4. JCLloyd
    JCLloyd New Member
    Oct 5, 2017
    112
    19
    The issue appears to be with the client (assuming Windows).
