Tele control
Discussion in '3CX Phone System - General' started by anaser, Nov 18, 2008.
  1. anaser
    Sep 19, 2008
    Dir Sir/Mad
    I have ADSL Router SAGEM F@st™ 2404/2444 i want open 3CX system form other Pc
    {by internet) I try this by useing Sagem 800 it was Successful but was not by sagem 2404
  2. aesteve
    aesteve New Member
    Sep 20, 2008
    136
    With this router i experience the same problem when register with the VoIp provider.
    I´m studing this case.
    If somebody know the problem i will agree to him.
  3. aesteve
    aesteve New Member
    Sep 20, 2008
    136
    I find the problem. The problem is the firewall that don´t appears in the web interface. I edit the cfg file and change the "firewall=enabled" to "disable", and restore the configuration.
    regards.
