telephon equipment connect to isdn??
Discussion in '3CX Phone System - General' started by Anonymous, Sep 25, 2006.
  1. Anonymous
    Anonymous Guest
    can i connect with this programm my telephone equipment with ISDN??
    thanks a lot
    ist es m
  2. 3CXsupport
    3CXsupport New Member
    3CX Support
    Aug 21, 2006
    I think you might be looking for a different verb than 'to shoot', but to answer your question it depends on what hardware you are taling about. If it is a simple ISDN gateway, then yes YOU can. Anything similar to the "Mediatrix 1402 ISDN BRI VoIP Gateway" should work.
    Also FYI we will be testing with EICON ISDN cards with the SIP drivers in the near future as well.
    Feel free to let us know if you have any further queries!.
