telephone number format
Discussion in 'Android' started by Frank D, Mar 3, 2016.
  1. Frank D
    Frank D New Member
    Oct 6, 2014
    215
    6
    it's really nice that you can use your existing telephone book on your smartphone with 3cxPhone (for Android or iOS). I experience the issue, that the number has to formatted in a specific way to work. Many numbers
    look like
    +49 173 XXXXXX
    where
    • +49 is the country code and
    • 173 the city or mobile network code without the zero
    Those calls won't process. How do you handle this? Using outgoing rules? Or is there an easier way? I think forcing everbody to edit their phonebook won't work.
    10,582
    250
    You would have to modify settings in 3CX to handle the +
    Have a look at this, and the link within...
    post84975.html
  3. Frank D
    Frank D New Member
    Oct 6, 2014
    215
    6
    Hi leejor,
    thanks for pointing me to the post.
    The image, which is showing the configuration is not available. But I figured it out. In my case I just had to add:
    Add Prefix: 0
    (was empty before)
    Works like a charm
    In V14 it's Settings->PBX->E164 (for other people looking)
