Teles VoipBox GSM 4 gateway
Discussion in '3CX Phone System - General' started by Ries, Jun 28, 2012.
  1. Ries
    Jun 28, 2012
    Hi all,
    Does anyone had experience with the Teles VoipBox GSM 4, as seen on the following page: http://www.voipmonster.com/voipbox-gsm-4.html ?
    Can this gateway be configured with the 3CX PBX without any problem?
    Thanks in advance for your reaction!
    Kind regards,
    Richard
