Telfort
Discussion in '3CX Phone System - General' started by matthijsolislagers, Jan 27, 2008.
  1. matthijsolislagers
    matthijsolislagers New Member
    140
    Anyone got 3CX working with the Dutch provider Telfort? If someone did, can you please post your settings.
    Thanks!
  2. landfiets
    landfiets New Member
    Jul 17, 2007
    243
    hi. Yes you can reach me by PM or MSN.
    I opened the ports in NAT: 5060-5080, 3478, 9000-9015
    I switched the firewall off because it gave terrible problems.
    But it is still not really what it shoudl be but it works fine including DR and VM
    Post me a PM and I will give you my MSN and/or phonenumber
  3. matthijsolislagers
    140
    With some help of landfiets I managed to get it working.
    The settings are:
    Registrar/Proxy Hostname or IP: tel.telefoniedienst.nl
    Outbound Proxy Hostname or IP: tel.telefoniedienst.nl
    External Number: your Telfort number
    Authentication ID: your Telfort number
    Authentication Password: your Telfort telephony password
  4. bbrink
    Oct 15, 2007
    11
    I'm having some trouble..
    [CM504005]: Registration failed for: 10000@Speedlinq; Cause: 408 Request Timeout; internal
    Does anyone know what is wrong?
    I have used the settings above.
  5. matthijsolislagers
    140
    It only works using your Telfort connection. Perhaps that is your problem
