- Joined
- Jan 8, 2008
- Messages
- 13
- Reaction score
- 0
Tell problem in the next 3 version of the program works fine, but we need a fax in connection with etii installed version 5, but she does not want to connect to the ISP in what might be the problem. I just tell you how to fax
Domain/Realm/registrar/Proxy-Server: sipnet.ru
Username/Athorization User name/Login/User id/Phone Number и т.п.: ВАШ SIP ID, например: 1234567
Password: ******
STUN server: stun.sipnet.ru:3478
14:50:45.656 ClientRegs:nFailure :[CM504005]: Registration failed for: [email protected]
14:50:13.500 ClientRegs::Register :[CM504003]: Sent registration request for [email protected]
14:48:43.609 Call::Terminate :[CM503008]: Call(4): Call is terminated
14:48:43.593 Call::RouteFailed :[CM503014]: Call(4): Attempt to reach [sip:[email protected]] failed. Reason: Not Registered
14:48:43.593 CallCtrl:nSelectRouteReq :[CM503015]: Call(4): Target is not registered: VoIPline:74955077777 dialed on ([email protected])
14:48:43.593 Line::Line :[CM303003]: There are no available outbound lines on gateway sipnet.ru at this time.
14:48:43.562 CallCtrl:nIncomingCall :[CM503001]: Call(4): Incoming call from Ext.102 to [sip:[email protected]]
14:43:24.000 ClientRegs::Register :[CM504003]: Sent registration request for [email protected]
14:43:22.718 ClientRegs::Register :[CM504003]: Sent registration request for [email protected]
14:43:03.546 ClientRegs::Register :[CM504003]: Sent registration request for [email protected]
14:42:42.062 ClientRegs::Register :[CM504003]: Sent registration request for [email protected]
14:42:40.875 StunClient:nInitTests :[CM506001]: STUN request to resolve SIP external IPort mapping is sent to STUN server 64.69.76.23:3478 over Transport 192.168.15.101:5060
14:42:39.375 FaxCfg::updateContact :[CM504008]: Fax Service: registered as sip:888@3CXPhoneSystem with contact sip:[email protected]:5100;user=phone
14:42:38.218 FaxCfg::updateContact :[CM504010]: Fax Service: unregistered contact sip:888:5100;user=phone
14:42:23.968 ClientRegs:nFailure :[CM504007]: Next attempt to register [email protected] is scheduled in 1 minute
14:42:23.968 ClientRegs:nFailure :[CM504005]: Registration failed for: [email protected]
14:42:19.468 ClientRegs::Register :[CM504003]: Sent registration request for [email protected]
14:42:16.328 ClientRegs::Register :[CM504003]: Sent registration request for [email protected]
14:42:07.531 ClientRegs::Register :[CM504003]: Sent registration request for [email protected]
14:41:19.468 ClientRegs:nFailure :[CM504007]: Next attempt to register [email protected] is scheduled in 1 minute
14:41:19.468 ClientRegs:nFailure :[CM504005]: Registration failed for: [email protected]
14:40:59.484 ClientRegs::Register :[CM504003]: Sent registration request for [email protected]
14:39:59.453 ClientRegs:nFailure :[CM504007]: Next attempt to register [email protected] is scheduled in 1 minute
14:39:59.453 ClientRegs:nFailure :[CM504005]: Registration failed for: [email protected]
14:39:54.625 ClientRegs::Register :[CM504003]: Sent registration request for [email protected]
14:39:15.234 ExtnCfg::updateContact :[CM504001]: Ext.101: new contact is registered. Contact(s): [sip:[email protected]/101]
14:38:54.593 ClientRegs:nFailure :[CM504007]: Next attempt to register [email protected] is scheduled in 1 minute
14:38:54.593 ClientRegs:nFailure :[CM504005]: Registration failed for: [email protected]
14:38:34.796 ClientRegs::Register :[CM504003]: Sent registration request for [email protected]
14:37:34.781 ClientRegs:nFailure :[CM504007]: Next attempt to register [email protected] is scheduled in 1 minute
14:37:34.781 ClientRegs:nFailure :[CM504005]: Registration failed for: [email protected]
14:37:30.093 ClientRegs::Register :[CM504003]: Sent registration request for [email protected]
14:36:30.093 ClientRegs:nFailure :[CM504007]: Next attempt to register [email protected] is scheduled in 1 minute
14:36:30.093 ClientRegs:nFailure :[CM504005]: Registration failed for: [email protected]
14:36:09.953 ClientRegs::Register :[CM504003]: Sent registration request for [email protected]
14:35:09.937 ClientRegs:nFailure :[CM504007]: Next attempt to register [email protected] is scheduled in 1 minute
14:35:09.937 ClientRegs:nFailure :[CM504005]: Registration failed for: [email protected]
14:35:05.437 ClientRegs::Register :[CM504003]: Sent registration request for [email protected]
14:34:05.437 ClientRegs:nFailure :[CM504007]: Next attempt to register [email protected] is scheduled in 1 minute
14:34:05.437 ClientRegs:nFailure :[CM504005]: Registration failed for: [email protected]
14:33:49.328 Call::Terminate :[CM503008]: Call(3): Call is terminated
14:33:49.312 Call::RouteFailed :[CM503014]: Call(3): Attempt to reach [sip:[email protected]] failed. Reason: Not Found
14:33:49.312 CallCtrl:nSelectRouteReq :[CM503013]: Call(3): No known route to target: [sip:[email protected]]
14:33:49.296 CallCtrl:nIncomingCall :[CM503001]: Call(3): Incoming call from Ext.102 to [sip:[email protected]]
14:33:45.109 ClientRegs::Register :[CM504003]: Sent registration request for [email protected]
14:32:44.906 ClientRegs:nFailure :[CM504007]: Next attempt to register [email protected] is scheduled in 1 minute
14:32:44.906 ClientRegs:nFailure :[CM504005]: Registration failed for: [email protected]
14:32:40.843 ClientRegs::Register :[CM504003]: Sent registration request for [email protected]
14:32:38.968 FaxCfg::updateContact :[CM504008]: Fax Service: registered as sip:888@3CXPhoneSystem with contact sip:[email protected]:5100;user=phone
14:32:38.218 FaxCfg::updateContact :[CM504010]: Fax Service: unregistered contact sip:888:5100;user=phone
14:31:40.718 ClientRegs:nFailure :[CM504007]: Next attempt to register [email protected] is scheduled in 1 minute
14:31:40.718 ClientRegs:nFailure :[CM504005]: Registration failed for: [email protected]
14:31:20.234 ClientRegs::Register :[CM504003]: Sent registration request for [email protected]
14:30:20.234 ClientRegs:nFailure :[CM504007]: Next attempt to register [email protected] is scheduled in 1 minute
14:30:20.234 ClientRegs:nFailure :[CM504005]: Registration failed for: [email protected]
14:30:15.843 ClientRegs::Register :[CM504003]: Sent registration request for [email protected]
14:29:48.062 ClientRegs::Register :[CM504003]: Sent registration request for [email protected]
14:28:25.531 ClientRegs:nFailure :[CM504005]: Registration failed for: [email protected]
14:28:25.218 Call::Terminate :[CM503008]: Call(2): Call is terminated
14:28:25.171 Call::RouteFailed :[CM503014]: Call(2): Attempt to reach [sip:[email protected]] failed. Reason: Not Found
14:28:25.171 CallCtrl:nSelectRouteReq :[CM503013]: Call(2): No known route to target: [sip:[email protected]]
14:28:25.046 CallCtrl:nIncomingCall :[CM503001]: Call(2): Incoming call from Ext.102 to [sip:[email protected]]
14:27:54.703 ClientRegs::Register :[CM504003]: Sent registration request for [email protected]
14:27:06.812 Call::Terminate :[CM503008]: Call(1): Call is terminated
14:26:39.468 CallCtrl:nLegConnected :[CM503007]: Call(1): Device joined: sip:[email protected]:5060
14:26:39.468 CallCtrl:nLegConnected :[CM503007]: Call(1): Device joined: sip:[email protected]:49152
14:26:37.109 CallCtrl:nSelectRouteReq :[CM503004]: Call(1): Calling: Ext:103@[Dev:sip:[email protected]:5060]
14:26:36.656 CallCtrl:nIncomingCall :[CM503001]: Call(1): Incoming call from Ext.102 to [sip:[email protected]]
14:25:24.453 ExtnCfg::updateContact :[CM504001]: Ext.103: new contact is registered. Contact(s): [sip:[email protected]:5060/103]
14:24:16.203 ClientRegs::Register :[CM504003]: Sent registration request for [email protected]
14:22:55.468 ExtnCfg::updateContact :[CM504001]: Ext.102: new contact is registered. Contact(s): [sip:[email protected]:49152/102]
14:22:45.187 ClientRegs::Register :[CM504003]: Sent registration request for [email protected]
14:22:44.531 CallMgr:nAddIPs :IP(s) added:[192.168.15.101]
14:22:41.281 ClientRegs::Register :[CM504003]: Sent registration request for [email protected]
14:22:41.203 StunClient:rocess :[CM506002]: Resolved SIP external IPort (217.15.51.96:5060) on Transport 192.168.15.101:5060
14:22:40.875 StunClient:nInitTests :[CM506001]: STUN request to resolve SIP external IPort mapping is sent to STUN server 64.69.76.23:3478 over Transport 192.168.15.101:5060
14:22:40.546 FaxCfg::updateContact :[CM504008]: Fax Service: registered as sip:888@3CXPhoneSystem with contact sip:[email protected]:5100;user=phone
14:22:38.593 FaxCfg::updateContact :[CM504009]: Fax Service: changed contact to sip:[email protected]:5100;user=phone
14:22:35.750 IVRConnected :[CM501004]: Connected: IVR Service
14:22:35.718 DBA :[CM501003]: Connected: Database
14:22:35.140 CallMgr::findLocalIPs :[CM501006]: Default Local IP address: [192.168.15.101]
14:22:34.562 MediaServerConnected :[CM112000] Media Server is connected
14:22:34.437 CallMgr::Initialize :[CM501002]: Version: 5.0.3790.0
14:22:34.421 CallCtrl::thread :[CM501007]: *** Started Calls Controller thread ***
14:22:34.421 CallMgr::Initialize :[CM501001]: Start 3CX PhoneSystem Call Manager
14:22:34.296 LoadLicenceInfo :[CM501010]: License Info: Load Failed
Password: ******
