Solved Template files stopped working
Discussion in '3CX Phone System - General' started by Gav, Nov 30, 2017.
  1. Gav
    Gav
    Oct 3, 2017
    46
    I've just upgraded to version 15.5 SP2. (15.5.6354.2)
    I'm using Fanvil X4 phones running firmware 2.3.1.4361.
    Previously I would edit the fanvil.ph.xml file located at ProgramData\3CX\Instance1\Data\Http\Templates\phones
    I could edit this file with various changes which, during phone provisioning, would configure phones in various ways.
    example - <Display_Name> %%extension_number%% | %%extension_first_name%%</Display_Name>
    Since upgrading 3CX, this has stopped working.
    I can see the fanvil.ph.xml file still has my changes, but the phones seem to completely ignore this.
    Example - the <Display_Name> setting above has changed to
    <Display_Name>%%extension_first_name%% %%extension_last_name%%</Display_Name>
    Has something changed to the way this works?
  2. Gav
    Gav
    Oct 3, 2017
    46
    Ignore this - fixed it
  3. apostolis_3CX
    apostolis_3CX Support Team
    Nov 1, 2017
    149
    15
    Glad to hear your issue was resolved
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,455
    541
    Hello @Gav
    Please note that it is not recommended to change the default templates. If you need to use custom templates it is best to create copies from the management console and apply your changes to those. Every there is a template update default templates are overwritten along with your changes. Also it is best to always have the default template to revert to if something isn't right.
