Template for Grаndstrеаm GXP2130/2140/2160
Discussion in '3CX Phone System - General' started by eagle2, Mar 5, 2015.
  1. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    Does anybody has a template or link to template for new Grаndstreаm phones GXP-2130/2140/2160 ?
    Earlier there was one on vendor's webpage, but probably deleted or moved.
  2. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,613
    243
    Here you go
    http://bit.ly/1BVrVqJ
  3. eagle2
    Apr 27, 2011
    1,085
    11
  4. north7
    Nov 9, 2010
    9
    Were you ever able to get these to work? We're testing the 2130 and they will not provision in V12 with or without that template and the latest firmware. It shows up in the console, and can be assigned to a new extension but never actually provisions.
    Also, I don't see why GS keeps these files from end users?
  5. north7
    Nov 9, 2010
    9
    Thanks for that! I installed per the instructions, but we still can't get these to provision at all.
    They are set to use the same option 66 url as our other 1405's, and they boot up and show up in the unassigned phones console, but after we assign them to a new extension or existing, nothing happens. No reboot or anything. We can reboot them, and they show up again as unassigned. the only evidence that they are hitting the PBX is the following notation in the logs:
    New SIP device is on-line: MAC:000B8264F0D1; ip=10.0.0.70; contact=sip:10.0.0.70:5080
    The above phone is assigned to a valid extension, and if I add a 1405 to that extension it provisions immediately.
    All the phones have 1.0.4.21 firmware and our PBX is 12.0 SP6.1
  6. eagle2
    Apr 27, 2011
    1,085
    11
    Is it possible to add template for Grаndstrеаm phones in V14, seems 3CX is not allowing adding custom templates ?
  7. eagle2
    Apr 27, 2011
    1,085
    11
    Does somebody created templates for Grandstream 21302140/2160 for 3CX version 15 ?
  8. dmayer
    Jul 8, 2016
    10
    Grandstream has taken the effort out of this, they make templates for 3CX, but you need to sign up to be a Grandstream reseller, that part is free. After you do so, it'll be on their reseller portal under marketing materials. It also allows you to submit a case and then call them as they won't allow callins for non-resellers.
  9. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
  10. dmayer
    Jul 8, 2016
    10
  11. eagle2
    Apr 27, 2011
    1,085
    11
    I found in Internet, but haven't tested yet, the following Grandstream templates for V.15 (WeTransfer link):
    https://we.tl/EVQJZFoCFB
    -- the link is valid for 1 week, if expired, I could send them to anybody sending me a private message with his email.
    #11 eagle2, Mar 6, 2017
    antfex likes this.
  12. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    305
    thanks for sharing...
  13. Panayiotis Panayiotou
    Mar 23, 2017
    Could you please post again the provisioning template for V15?
    Thank you in advance!
  14. ovj666
    Apr 23, 2017
    Could you share link for grandstream template again, Thank you
  15. antfex
    Jul 29, 2017
    Could you share link for grandstream template again ?
  16. jpenberthy
    May 31, 2010
    7
    Could I also get the link, also does it include the newer GXV series?
  17. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    220
    bort and antfex like this.
  18. bort
    Sep 8, 2017
    I desperately need a GXP2130 template for V15. Could someone please post it again.
  19. cobaltit
    Mar 22, 2012
    1,613
    243
    bort likes this.
  20. Bret Gordon
    Jun 16, 2017
    24
    Grandstream support is good. They have provided me with 3cx templates over at their forum (see my thread here on the GXP 1620/1625). Just go over there and ask. :)
    bort likes this.
