Template for Polycom VVX 300/400?
Discussion in '3CX Phone System - General' started by SEISupport, Jun 19, 2013.
  1. SEISupport
    Jun 19, 2013
    5
    Hello - Just purchased 3CX, did a lot of homework to get there. This is one thing bothering me, I don't know if I should use/duplicate the Polycom.ph.xml template with alterations to have a "Custom VVX 300" entry or if there is some other template (like from V12) that I should be using with them. Haven't provisioned any of them coming in today so a direction would be appreciated.
  2. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,773
    278
    There are no templates for any of the VVX phones in v12 currently.
  3. pjr
    pjr New Member
    Oct 5, 2009
    154
    I havent had chance to install V12 yet but can anyone confirm that there are Polycom templates in V12?
    I know 3CX are not fans of Polycom phones and provisioning them but just want to ensure that templates exist for them in V12
    Paul
