"Template Name" drop down field not big enough
Discussion in 'Ideas' started by r.towle, Mar 17, 2016.
  1. r.towle
    Apr 11, 2013
    67
    10
    Please make the "Template Name" drop down field under "Provisioning Templates" larger so you can read the entire name of the template.
    This is particularly needed if you customise templates and you cant see the full name.
  2. andrea.soc
    Feb 24, 2016
    38
    7
    it would be useful
  3. 3CXusername
    3CXusername New Member
    Jul 31, 2014
    183
    16
    the little things. I could use this as well.
  4. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    15
