Template to configure 3cx Softphones - IN PROGRESS
Discussion in 'Ideas' started by wtrbhe, Jan 28, 2016.
Template to configure 3cx Softphones - IN PROGRESS 5 5 1votes
5/5, 1 vote
  1. wtrbhe
    Oct 9, 2015
    22
    A template to set up things in Softphones would be great, for example I like to switch off the record button, set some parameters, disable buttons and menu entrys.
  2. Frank D
    Frank D New Member
    Oct 6, 2014
    215
    6
    Re: Template to configure 3cx Softphones
    Nice idea.
    I wanted to set some default values, like the
    "rfc2833 inband" for dtmf
    I thought there is a template for the config file somewhere in the filesystem. Is this correct? Anyway, having a template and some more options would be nice.
  3. cfive
    cfive Member
    Aug 20, 2009
    284
    Similarly,
    Groups of extensions may have BLF's in 3CXPhone (and hardphones, for that matter) configured in a certain way. It's extremely time consuming and error-prone to set these for each extension individually. A couple of tick boxes might do the trick - one idea: "copy BLF settings from Extension: nnnn".
  4. jhonku
    Mar 25, 2016
    24
    5
    Interesting requirement.
    It could be great to define 3CXPhone Behavior parameters. Define executable path and parameters on ringing for example.
  5. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,889
    191
    Centralized management of softphone settings, and deploying of CRM scripts is in development for the next version....
    So is copying of extension settings to another extension
    the60 likes this.
