- Joined
- Feb 7, 2011
- Messages
- 12
- Reaction score
- 1
I wrote this suggestion in the ideas portal:
http://www.3cx.com/ideas/index.php?page=idea_detail.php&i=1972
Please vote it if you hade trouble during 3cx phone system update with customised template
Alessandro
With v14 you had a huge change in the template customisation, with the automatical duplication of the template and the customised template folder,
but the problem is still the same: when you update the 3cx phone system you have a fork: the customised template could not match in important parameter with the updated basilar one.
95% of the customisation are single, overwriting parameters, so I think that you can store it separately and apply it after the basilar one is generated.
In this way the basilar template changes can be applied immediately also to the customised one.
Alessandro
