Templates for patton 4634 - 3cx v9
dbagiacchi
I'm desperately looking for a template that allows to use updated 3 BRI lines for the Patton SmartNode 4634 for 3cx version v9. help me please
Use the 4638 template and remove line 3+4 from the configuration file.
But you can only use 2 BRI, the 3rd you can only use as failover port.
Right now I manage it well. I was looking for a solution that could make use all 3 lines. In this forum there is any user that uses all 3 lines. Thanks
Get 3CX - Absolutely Free!
3CX
