Templates for Yealink T49G
Discussion in 'Ideas' started by KaiK, Mar 14, 2018.
  1. KaiK
    Mar 14, 2018
    Please add support for the Yealink T49G. We used Askozia and they had a great template in place. So its there, please just adapt. Thanks!
    Kai
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    305
    wow that is one pricey$$$ phone.
