Tenant ?
Discussion in '3CX Phone System - General' started by shedster99, Aug 3, 2010.
  1. shedster99
    Aug 3, 2009
    29
    If 3CX doesn't support multi-tenant installs, what is the reference to tenants in the postgreSQL database and the API ( http://www.3cx.com/phone-system/hotel-pbx.html ) ?
    tia...
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,557
    118
    No, the 3CX PBX currently does not support multitenant installs.
    This is something we "may" add in version 10. It's not a promise, but a possibility.
  3. shedster99
    Aug 3, 2009
    29
    Thanks, having a scout around the forums it looks like it could be a seller especially if the pricing model was based on the current concurrent call model.
    So the database structure and API usage is purely for future use/development ?
    Do you have a link to the development roadmap (if one exists) I couldn't find one...
  4. andrewbucklin
    Jun 30, 2011
    12
  5. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    If I was 3CX and I saw that only 12 people for this, I certainly would not put any development resources behind it.
  6. netswork
    netswork Active Member
    Mar 11, 2011
    577
    Thats why we need more votes :)
    We host our customers servers in our datacenter and a multi-tenant option would be very be beneficial. Granted its not the most important thing I would like to see changed but would be a very nice added feature.
  7. mylove4life
    mylove4life New Member
    Jan 7, 2010
    165
    I also dont see the need, why have it?
  8. custodian
    Dec 17, 2010
    22
    I know it's a fairly old post, but I just had to respond because Wow! That's a really short-sighted view. There are many other resellers and users of 3CX and we do see the need for it. I'll give you an example of a managed office where the office landlord provides phones for each rented out office. The ability to keep the offices separate is very important.
    Another example would be if you wanted to use 1 3CX system in your head office, but had different branches that were essentially different companies so wanted to keep them separate.
    I hope 3CX doesn't take your view of "we don't see the need ourselves so we won't implement it". Software would be so much more limited if people did that.
  9. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    multi-tenant is now available
  10. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    What will be the licensing model for multi-tenant version ?
    Will each tenant need separate licenses for simultaneous calls or licenses will be dynamically shared between the tenants ?
    I regard this quite important question.
    Regards
  11. andrewbucklin
    Jun 30, 2011
    12
    Each tenant will need their own license, but you can mix and match licenses. For example, one tenant can have a 16-channel call center edition while another can have a 4-channel standard edition, and another can be on a free trial license.
  12. davidbenwell
    Apr 27, 2010
    704
    From my understanding the licensing is the normal way
    Each instance of 3CX will require its own edition licence.
  13. eagle2
    Apr 27, 2011
    1,085
    11
    This sounds most reasonable -- my expectation is the same -- each tenant needs separate license.
    Regards
