Terminating calls at 3CX IVR
Discussion in '3CX Phone System - General' started by kegler, Jan 25, 2007.
  1. kegler
    Jan 16, 2007
    Is it possible to use the IVR component of 3CX without having to start the rest of the PBX? For example, terminate a SIP call directly to the IVR component to play an announcement.
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    No, it isn't possible. IVR is controlled by Call Manager, and doesn't have own SIP stack. You cannot make SIP connection to it.
    Why do you need such an ability? Why not to reach IVR just as supposed thru simple call?
