Tesco Sip provder UK
Discussion in '3CX Phone System - General' started by Richardb, Jan 28, 2010.
  1. Richardb
    Jan 28, 2010
    Im trying to connect my 3CX system to the Uk tesco Internet SIp provider. I can get the 3CX to register ok... but I cant get calls in. I have the ports open and the port forwarding sorted....so im now out of ideas. anybody got any tips?
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Hi Richard,
    It been repeated hundreds of times and it is the subject of the topmost topic on this forum:
    http://www.3cx.com/forums/forum-rules-read-to-get-answers-93.html
    set verbose log level and then restart PBX...
    To be sure that the SIP traffic sent by provider reaches PBX host, you can use WireShark. It will show you all incoming packets comin to PBX host. If there are no SIP requests received from VoIP provider then problem can be described in PBX log.
    Thanks and Welcome to our forum :)
