Test install: Login does not work!
Discussion in '3CX Phone System - General' started by jc, Jun 30, 2007.
  1. jc
    jc
    Jun 30, 2007
    I installed the 3CX version 3. The initial logon says the login is incorrect. I get the same result even after reinstallation.
    Anybody knows why?
    Thanks.
    JC
  2. Anonymous
    Anonymous Guest
    what did you enter during the installation as login? That is the one to use.
  3. jc
    jc
    Jun 30, 2007
    Thank you, Henk.
    That was good.
    I think what happened was hat the download was too old. I downloaded the next version and it worked. Now the problems are more complex. Ha, ha!!
    JC
  4. Anonymous
    Anonymous Guest
    A problem is only if you make it one :).
    Every problem has a solution, otherwise it would not be a problem by definition (gosh we getting deep now :))
