Testing Fax Server
Discussion in '3CX Phone System - General' started by georgewillow, Apr 13, 2012.
  1. georgewillow
    Apr 13, 2012
    16
    Shouldn't I be able to call 888 internally and hear a fax tone? My call just gets terminated after a split second. I'm also getting this when I call in remotely, but I thought I could verify it was working just by dialing 888 internally.
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    305
    i tried and get same result.
    maybe it knows I am calling from a sip phone and not a fax machine?
    I do not have an inbound line available right now to test.
  3. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    No. 3CX only supports T.38 fax, not analog fax so there is no negotiation tones.
  4. craigreilly
    Feb 1, 2012
    3,575
    305
    So that means a normal fax machine in someone's copy room couldn't reach us?
  5. leejor
    11,117
    329
    It means that any incoming fax has to come from a VoIP provider that supports T.38, or a PSTN gateway that does (there are a few around). I suppose you could try an internal fax machine that uses an ATA that supports T.38, and the options set correctly, calling 888.
    http://en.wikipedia.org/wiki/T.38
