Text to speech
Discussion in 'Call Flow Designer' started by Federico Moschini, Feb 7, 2018.
  1. Federico Moschini
    Jan 6, 2017
    28
    I tried to make a demo but when compile I receive this mistake
    Unexpected character '$'
    I put as your sample the following function
    CONCATENATE("Your account balance is $",callflow$.AccountBalance)
    Where is the mistake ?
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,080
    77
    Hello @Federico Moschini,
    That error is usually caused by missing quotes in a constant string. Did you define the callflow variable "AccountBalance"? Can you show exactly the error you receive (including the line and column number)?
    Kind regards.
  3. Federico Moschini
    Jan 6, 2017
    28
    Can you show me here and how create the "AccountBalance" callflow ? I didn't find in the step by step manual.
    Thank you.
  4. edossantos
    Jun 27, 2007
    1,080
    77
    In the Project Explorer window, select the callflow object. Then go to the Properties Window and click on the button on the right of "Variables". There you can add your variable.
