- Joined
- Jan 4, 2016
- Messages
- 73
- Reaction score
- 25
Just wanted to throw this out there for anyone looking on setting up TFTP for older phones like Cisco 79xx series. Just a note - all commands are in italics.
Things you will want to have handy.
WinSCP and Putty.
I used WinSCP to find the provisioning instance folder which is located in /var/lib/3cxpbx/Instance1/Http/Interface/provisioning/
Open the provisioning XXXXXXX and use WinSCP to transfer the Cisco files.
If you don't have them you can find them here.
Just a little note, don't copy the folder and contents to the directory, just the contents.
Use Putty to ssh to your PBX or terminal if you are on a Mac.
Once connected you will need to install a TFTP server. For this I used tftp-hpa.
To install type:
sudo apt-get install tftpd-hpa
Your TFTP server is now installed. Now we need to edit the config file.
You can use vi or nano, I prefer nano to edit.
sudo nano /etc/default/tftpd-hpa
Edit the config file to reflect your provisioning directory. Don't forget the start and end quotes!
TFTP_USERNAME="tftp"
TFTP_DIRECTORY="/var/lib/3cxpbx/Instance1/Data/Http/Interface/provisioning/XXXXXXXX"
TFTP_ADDRESS="0.0.0.0:69"
TFTP_OPTIONS="--secure"
Write and exit Nano (use ctrl+O to write and ctrl+X to exit)
Now we need to make our changes active.
Type these commands:
service tftp-hpa stop
service tftp-hpa start
And that is all it takes to setup TFTP on your 3CX Debian server.
WinSCP and Putty.
To install type:
