thanks for new version
Discussion in '3CX Phone System - General' started by ilkeryildiz, Mar 7, 2007.
  1. ilkeryildiz
    Jan 7, 2007
    26
    new version is good work
    thanks.
    VoIP Outbound Rule suggestion:
    I can choice voip provider but i can't choice "line" under provider.
    I have two account at one provider. I want create rule some extensions a account and other extensions another account.
    You must add lines choice at menu.
  2. 3CXsupport
    3CXsupport New Member
    3CX Support
    Aug 21, 2006
    193
    Thanks very much for the encouraging words!
    Thanks for the suggestion too, we are aware of this current limitation.
