the 5.0.376M.0
Discussion in 'Windows' started by asfuture, Dec 28, 2007.
  1. asfuture
    asfuture New Member
    Aug 3, 2007
    156
    how kan i use Outlook wtih the desk mode from 3CX Voip client???
  2. Wardy
    Wardy New Member
    Sep 18, 2007
    110
    Which version of 3CX are you using and is it the free version
  3. asfuture
    asfuture New Member
    Aug 3, 2007
    156
    i use the last ultimate version van 3cx
  4. asfuture
    asfuture New Member
    Aug 3, 2007
    156
    and now??? no reaction??? i need some support. i hope that the 3CX me can help
  5. silentfun
    silentfun Member
    Dec 11, 2006
    364
    First there is no ultimate version (van) 3cx
    http: //www.3cx.com/manual/3CXVOIPclientmanual5.pdf
    this is V5 VOIP Client Manual you can find the Answer on Page 17
    Andy
