The basics
Discussion in '3CX Phone System - General' started by hitchins, Dec 28, 2011.
  1. hitchins
    Jul 26, 2011
    Right, I've installed 3CX in a new environment. All SIP providers are registered and all internal soft/hard phones work. I can make incoming & outgoing calls no problem.
    I can't however get external soft phones to work. I can see from the debug log it says it's connected, then ended by the server.
    Do I have to open & forward 9000 > 9049 to get this working? I thought the 3CX Tunnel would negate the need for this.
    Also, apart from the Event and System logs, is there a real time log I can see each connection coming in as?
    All help gratefully received!
    10,567
    246
    I have to assume that you are running the tunnel option on the remote 3CX phones, if so then only port 5090 is used. What does the 3CX log show for a call attempt?
  3. hitchins
    Jul 26, 2011
    Hi there, thanks for the help.
    This is what I see on the 3CX Soft phone debug view. Using an online port scanner I can see that 5060 and 5090 show as open.
    EDIT: Is there a Tunnel log server side I can view?
    Tunnel is attempting to connect remote tunnel 123456 [xxx.xxx.xxx.xxx:5090]
    Tunnel connection established
    Tunnel has been disconnected by remote end
    Tunnel send from phone to PBX: REGISTER
    ************ debug paused ***********************
  4. leejor
    10,567
    246
    There is a log in the 3CX PBX, that is the one you should be looking at as it may give a clue as to why the registration attempt is being dropped. If there is nothing in there, then the requests are not getting past your router.
    I assume that you set up the Tunnel password.
  5. hitchins
    Jul 26, 2011
    Is that the Server Activity Log in 3CX admin, above the Server Event Log? Or do I need to be looking somewhere else?
  6. hitchins
    Jul 26, 2011
    OK, feel rather stupid, but I got there thats the main thing.
    I noticed the "Disalow use of extension outside the LAN".
    Putting the logging mode to verbose enabled me to see that WAN requests were blocked, quick google and a thread on here put me in the right direction.
    Many thanks for you help lee
  7. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    For registering external extensions via 3CX tunnel you DON'T need to enable outside of LAN registrations in extension settings (as well as if you are using VPN / VLAN). In your case this most probably means you are not configuring correctly remote extensions / tunnel.
    Regards
