The Call Assistant what Port if i use it from EXTERN network
Discussion in '3CX Phone System - General' started by silentfun, May 20, 2007.
  1. silentfun
    silentfun Member
    Dec 11, 2006
    364
    The Call Assistant what Port if i use it from EXTERN network?
  2. silentfun
    silentfun Member
    Dec 11, 2006
    364
    also solved it need the port of the apache server that is default http://your_server:5481 to use the assistant from external network u have to forward the outside port to your server through your router.
    it is a TCP/IP forwarding
    have fun
  3. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,939
    250
    Hi Silentfun!
    Thanks for the update!
    To be honest we had not tested if the Call Assistant works from outside the network.... We just knew it should work in theory.
    Pleased to hear its tested and working though!
  4. silentfun
    silentfun Member
    Dec 11, 2006
    364
    it works fine but if the server reboot or other issues don
