The cloudest 3CX
Discussion in '3CX Phone System - General' started by CoolW, Sep 14, 2016.
  1. CoolW
    Sep 14, 2016
    Hi.
    I was wondering if you guys could help, I've setup a test server in azure and that's working fine but I just needed to clarify a few things, I've had a look around the forums but couldn't find anything definitive:
    Is it possible to run a remote site with <30 users without a SBC?
    Can you have multiple tunnels coming from one IP?
    Are CTI features still only available via SBC for external users or can you use STUN or tunnel?
    Cheers!
    10,360
    226
    I can answer a couple...
    You will probably end up with a lot of (audio amongst other) issues if you try setting up a remote site of more than a couple of sets, and not using the SBC. You could try passing all audio back through the PBX, but, for a large site, it is a waste of bandwidth.
    A tunnel is to one remote IP, so , one IP at the server end, but you'd need multiple pubilc IP's at (one?) remote location to use more than one tunnel.
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,349
    274
    CTI is still only available via SBC for remote users i am afraid
