"The user is unavailable"
Discussion in '3CX Phone System - General' started by jwnesbitt, Sep 19, 2009.
  1. jwnesbitt
    Sep 19, 2009
    48
    Hello all
    This is my first experience with a virtual PBX
    I setup an account with soho66 and that works perfectly
    i then tried to add a second VOIP provider - poivy.com (sip.poiy.com), but everytime i try to make a call through it, i get the error
    The 2 accounts are setup identically
    any ideas ?
    Jody
    11,086
    325
    By making a call through it, I assume you mean from the outside into the extension via that VoIP provider? Can you make outgoing calls over both providers? What do the 3CX logs show when a call comes in over each VoIP trunk? Compare the logs from the working one and the one that fails, does a call even show up from the second provider. I assume that both are showing up as registered in 3CX?
  3. jwnesbitt
    Sep 19, 2009
    48
    I was only trying outgoing calls
    when i use soho66 as the provider, it makes outgoing calls
    when i setup sip.poivy.com with the same rules and delete the soho66 account to make sure there are no conflicts, i get the error "The user is unavailable" when trying to make calls
    Jody
  4. jwnesbitt
    Sep 19, 2009
    48
    I uninstalled 3cx and re-installed and its working fine now, so must have been something I did
    thanks
    Jody
