the whole media in slow motion
Discussion in '3CX Phone System - General' started by pkoshcom, Jun 19, 2007.
  1. pkoshcom
    Jun 7, 2007
    5
    auto attendant, all prompts, are in slow motion, what do I do, its the first time the system started working.
  2. Anonymous
    Anonymous Guest
    What does that mean in slow motion?
    Does it sound like the "tape" is going to slow? or has it bits missing?
    The first is due to Mhz in the voice file and play back.
    Second one is due to priority on the network or running out process power on your 3CX box (eg processor or disk IO, make sure your disk is defraged)
  3. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Hi pkoshcom,
    Please describe hardware(software) configuration of host where PBX is installed.
    Thanks,
    Stepan
  4. pkoshcom
    Jun 7, 2007
    5
    DTMF detection is turned off
    Now I'm getting in the server status, MS problem (MS is turning Red)
    when I'm dialing an extension from the digital receptionist, it terminats the call with an error message "DTMF tone detection is turned off"
    where do I turn it on ???
  5. Anonymous
    Anonymous Guest
    DTMF should be on all the time, not sure if you actually can turn it on or off with the software.
    There migth be an issue with your codecs.
    Make sure you have G711 on all your devices.
    H
