ThinkTel SIP Trunk template issue
Discussion in '3CX Phone System - General' started by Samson Wu, Feb 27, 2017.
  1. Samson Wu
    Feb 27, 2017
    Created a SIP Trunk using the latest ThinkTel SIP Trunk template in 3CX V15 SP4. Filled in the correct outbound proxy IP, 206.250.80.100. But when making outgoing calls the 3CX server kept attempting to connect the calls to IP, 206.250.80.20, of course all failed.
    Anybody here can have the magic to push 3CX engineers check this issue?
    Thanks,
  2. Patrick Hogan10
    Nov 23, 2016
    27
    Any resolution to this yet? 3CX engineers, please help us out with this issue.
  3. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    ... what's the outbound proxy you put ?
  4. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    I just went through the thinktel template and the only IP that's in there is 206.80.250.100. You mentioned 206.250.80.100... did you maybe type it wrong in 3cx too ? Either way this doesn't seem like a 3cx issue ...
  5. Samson Wu
    Feb 27, 2017
    I put 206.250.80.100 as the outbound proxy. But calls try to connect to 206.250.80.20 anyway. Don't know where 3cx picked up this wrong IP.
  6. Samson Wu
    Feb 27, 2017
    206.250.80.100. But calls went to 206.250.80.20
  7. Samson Wu
    Feb 27, 2017
    Sorry please ignore my typo in the previous reply. I put 206.80.250.100, but calls went to 206.80.250.20.
  8. GiannosC_3CX
    GiannosC_3CX Guest
    Hi Samson,
    I have sent you a p.m.
