This call cannot be completed about the alert
Discussion in 'CRM / Helpdesk / App Integration' started by alidogu, Aug 11, 2015.
  1. alidogu
    Jul 13, 2015
    I'm trying to do projects with Voice Application Designer, but "this call can not be completed" will give. system based on Windows 2012. project works in a simple way as in the picture. and I added the following log files.
    Thank you for your attention.
    Code:
    10:52:12.052|8196|PbxMedia\IVREngine.cpp(1609):IvrService, IVREngine::RegisterLines(), Registering of lines...127.0.0.1:5060127.0.0.1:50609999[HOL,7777,855,851,857,856][][EndCall,IVRForward,MakeCall,PlayFile,RecordFile]
    10:52:12.052|8196|PbxMedia\IVREngine.cpp(1666):IvrService, IVREngine::RegisterLines(), Registering IVR:856
    10:52:12.053|8196|PbxMedia\IVREngine.cpp(1735):IvrService, IVREngine::RegisterLines(), Registering of lines done.
    10:52:54.745|12752|(0):Error! Module '3CX.com.vxi'. Error ID 999. messageXML parsing error in file ALITEST_2/Main.aspx?dr=856&to=856&from=1100, line 1: Invalid document structure
    10:52:54.745|12752|(0):Error! Module '3CX.com.vxi'. Error ID 205. uriALITEST_2/Main.aspx?dr=856&to=856&from=1100
    10:52:54.746|12752|api\VXIpromptImpl.cpp(212):IvrDll, VXIpromptImpl::Impl::Queue(), Error! A serious error within IVR session
    10:52:54.746|12752|VXIMachine.cpp(806):IvrDll, CallSession::RegisterPrompt(), Added prompt C:\Program Files\3CX PhoneSystem\Bin\..\Data\Ivr\Media\error.wav
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Hi there!
    What version of the VAD are you using? I see the error "Invalid document structure" which is something we have fixed some time ago.
    Currently the latest version is 14.0.4103.0 and you can download it from here:
    http://downloads.3cx.com/downloads/3CXCallFlowDesigner.exe (new link for v15.5)
    Please, check if you need to upgrade, and in that case do it and retry. Let us know if the issue is fixed after that.
    Kind regards.
  3. alidogu
    Jul 13, 2015
    thank you for reply. I am using the 12.5.3967 version. I'll try to update version.
