This Call Could Not Be Completed
Discussion in '3CX Phone System - General' started by TSlocum, Nov 14, 2013.
  1. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    15
    We're in the testing phase before rolling out a voip system with 3CX. We recently set up our Patton gateway, but were running into problems because we changed the IP on the Voip server. We finally got it all set up with a VLan, but now I can't get through to voicemail or other similar extensions such as 7777 - IVR. I get "This call could not be completed."
    How can I fix this?
    I've tried nearly every step on this page http://www.3cx.com/blog/docs/troubleshooting-iis-ivr/
    Missing Prompts: I have only one prompt set, so I can't change it.
    Disable Keepalives: There is no 'properties' option when I right click anything in IIS.
    IVR VXML services listening on port 5484: There is no IVR VXML service running. It's not listed in 3CX or Windows Services.
    3CX IVR Website assigned to App Pool: It is assigned.
    MIME settings: .vxml wasn't in the list, I added it per the instructions with no change
    Confirm HTTP compression disabled: There is no 'properties' option when I right click anything in IIS.
    Correct Permissions: Set permissions per the instructions, no change. As for IIS permissions, There is no 'properties' option when I right click anything in IIS.
    IIS installs with many websites: no other websites
    Sharepoint: No SharePoint on this server
    root.vxml: File is not blank
    Here's a screenshot of my right-click menu in IIS, there is no 'Properties': [​IMG]
    Here's the server logs for when I tried to call 7777:
    Code:
    14-Nov-2013 14:35:51.396	Leg L:17.2[Ivr] is terminated: Cause: BYE from PBX
    14-Nov-2013 14:35:51.396	[CM503008]: Call(C:17): Call is terminated
    14-Nov-2013 14:35:51.395	Leg L:17.1[Extn] is terminated: Cause: BYE from 10.11.226.101:5060
    14-Nov-2013 14:35:47.184	[CM503007]: Call(C:17): Ivr:7777 has joined, contact <sip:7777@127.0.0.1:40600>
    14-Nov-2013 14:35:47.181	[CM503007]: Call(C:17): Extn:1051 has joined, contact <sip:1051@10.11.226.101:5060>
    14-Nov-2013 14:35:47.179	L:17.2[Ivr] has joined to L:17.1[Extn]
    14-Nov-2013 14:35:47.029	[CM503025]: Call(C:17): Calling T:Ivr:7777@[Dev:sip:7777@127.0.0.1:40600;rinstance=a009be1a12e53305] for L:17.1[Extn]
    14-Nov-2013 14:35:46.983	[CM503027]: Call(C:17): From: Extn:1051 ("[User]" <sip:1051@10.11.226.247:5060>)  to  T:Ivr:7777@[Dev:sip:7777@127.0.0.1:40600;rinstance=a009be1a12e53305]
    14-Nov-2013 14:35:46.983	[CM503004]: Call(C:17): Route 1: from L:17.1[Extn] to T:Ivr:7777@[Dev:sip:7777@127.0.0.1:40600;rinstance=a009be1a12e53305]
    14-Nov-2013 14:35:46.979	[CM503001]: Call(C:17): Incoming call from Extn:1051 to <sip:7777@10.11.226.247:5060>
    11,105
    329
    This IP seems to initiating the disconnect. Is that the extension? Does this happen with other extensions?
  3. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    15
    10.11.226.101 is the extension. It happens with any extension.
  4. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    65
    Can you post the log in verbose mode as well as describing your setup? It would be helpful to know which version of 3cx and if paid or demo or free and how you are testing (what phone, models, etc. and the steps used to test). The issue I am struggling with is that you have two IPs for the same extension getting involved.
    You show:
    1051@10.11.226.247:5060 (which is the IP that placed the call)
    1051@10.11.226.101:5060 (which is the IP that joined to the IVR and subsequently ended the call with the BYE)
    I don't think this to be an IIS issue at all.
  5. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    15
    10.11.226.247 is the Voip server
    10.11.226.101 is the phone.
    3CX Paid version 12.0.32816.397 SP.2
    Cisco SPA514G phone on firmware 7.5.5
    I had to restart the 3CX services to enable verbose logging. When they came back on, the phone I was originally testing doesn't connect to the error message
    when trying to call voicemail. It just keeps ringing. I tried it on another phone (logs below) and it still goes to "This call could not be completed..."
    The IP on the second phone is 10.11.226.102
    Code:
    18-Nov-2013 11:54:12.110	L:8.1[Extn]: Terminating targets, reason:
    18-Nov-2013 11:54:12.110	Leg L:8.1[Extn] is terminated: Cause: BYE from PBX
    18-Nov-2013 11:54:12.110	Terminated from "Claudia"<sip:1004@10.11.226.247>;tag=3b77e766512a595o0 to "Voice Mail"<sip:9999@10.11.226.247>;tag=65727d29; reason: LocalBye
    18-Nov-2013 11:54:12.110	L:8.1[Extn] Sending: OnSendReq Send Req BYE from 0.0.0.0:0 tid=e20a33351e55fe56 Call-ID=16f147a-12a53b91@10.11.226.102:
    			BYE sip:1004@10.11.226.102:5060 SIP/2.0
    			Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-e20a33351e55fe56-1---d8754z-;rport
    			Max-Forwards: 70
    			Contact: <sip:9999@10.11.226.247:5060>
    			To: "Claudia"<sip:1004@10.11.226.247>;tag=3b77e766512a595o0
    			From: "Voice Mail"<sip:9999@10.11.226.247>;tag=65727d29
    			Call-ID: 16f147a-12a53b91@10.11.226.102
    			CSeq: 2 BYE
    			Content-Length: 0
    18-Nov-2013 11:54:12.110	SendMsg from "Voice Mail"<sip:9999@10.11.226.247>;tag=65727d29 to "Claudia"<sip:1004@10.11.226.247>;tag=3b77e766512a595o0
    18-Nov-2013 11:54:12.110	[CM503008]: Call(C:8): Call is terminated
    18-Nov-2013 11:54:12.110	L:8.1[Extn]: Terminating targets, reason: SIP ;cause=200 ;text="Call terminated on user request"
    18-Nov-2013 11:54:12.108	Blocking refers for the Call(C:8)
    18-Nov-2013 11:54:12.108	Call(C:8) is terminated
    18-Nov-2013 11:54:12.108	L:8.2[VMail]: Terminating targets, reason: SIP ;cause=200 ;text="User hangup"
    18-Nov-2013 11:54:12.108	Leg L:8.2[VMail] is terminated: Cause: BYE from 127.0.0.1:40600
    18-Nov-2013 11:54:12.107	L:8.2[VMail] got Terminated Recv Req BYE from 127.0.0.1:40600 tid=b86cea3228481f4f Call-ID=YjM5YmI3ZjRhNWY5YTRmZTM3NzA1NTViMjY5NDMwYzQ.:
    			BYE sip:1004@127.0.0.1:5060 SIP/2.0
    			Via: SIP/2.0/UDP 127.0.0.1:40600;branch=z9hG4bK-d8754z-b86cea3228481f4f-1---d8754z-;rport=40600
    			Max-Forwards: 70
    			Contact: <sip:9999@127.0.0.1:40600;rinstance=9a20cb43be6bdf2c>
    			To: "Claudia"<sip:1004@127.0.0.1:5060>;tag=ca34d518
    			Call-ID: YjM5YmI3ZjRhNWY5YTRmZTM3NzA1NTViMjY5NDMwYzQ.
    			CSeq: 2 BYE
    			User-Agent: 3CX Voice Mail Menu
    			Reason: SIP;description="User Hung Up"
    			Content-Length: 0
    18-Nov-2013 11:54:12.107	Terminated from <sip:9999@127.0.0.1:5060>;tag=9e4dfc5f to "Claudia"<sip:1004@127.0.0.1:5060>;tag=ca34d518; reason: RemoteBye
    18-Nov-2013 11:54:12.107	L:8.2[VMail] Sending: OnSendResp Send 200/BYE from 0.0.0.0:0 tid=b86cea3228481f4f Call-ID=YjM5YmI3ZjRhNWY5YTRmZTM3NzA1NTViMjY5NDMwYzQ.:
    			SIP/2.0 200 OK
    			Contact: <sip:1004@127.0.0.1:5060>
    			CSeq: 2 BYE
    			Content-Length: 0
    18-Nov-2013 11:54:12.107	SendMsg from "Claudia"<sip:1004@127.0.0.1:5060>;tag=ca34d518 to <sip:9999@127.0.0.1:5060>;tag=9e4dfc5f
    18-Nov-2013 11:54:08.485	Currently active calls - 1: [8]
    18-Nov-2013 11:54:04.008	Session 402 of leg L:8.1[Extn] is confirmed
    18-Nov-2013 11:54:04.008	L:8.1[Extn] got Confirmed Recv Req ACK from 10.11.226.102:5060 tid=-141a0dfa Call-ID=16f147a-12a53b91@10.11.226.102:
    			ACK sip:9999@10.11.226.247:5060 SIP/2.0
    			Via: SIP/2.0/UDP 10.11.226.102:5060;branch=z9hG4bK-141a0dfa
    			Max-Forwards: 70
    			Contact: "Claudia"<sip:1004@10.11.226.102:5060>
    			To: "Voice Mail"<sip:9999@10.11.226.247>;tag=65727d29
    			From: "Claudia"<sip:1004@10.11.226.247>;tag=3b77e766512a595o0
    			CSeq: 102 ACK
    			Proxy-Authorization: Digest username="1004",realm="3CXPhoneSystem",nonce="414d535c089ad72b55:44df26049009dcc76a3a2b1a1e819af2",uri="sip:9999@10.11.226.247:5060",algorithm=MD5,response="bc178c76278d5ccca78cb70cc4c24b9d"
    			User-Agent: Cisco/SPA514G-7.5.5
    			Content-Length: 0
    18-Nov-2013 11:54:04.008	ConnCfmd from "Claudia"<sip:1004@10.11.226.247>;tag=3b77e766512a595o0 to "Voice Mail"<sip:9999@10.11.226.247>;tag=65727d29
    18-Nov-2013 11:54:03.643	[CM503007]: Call(C:8): VMail:9999 has joined, contact <sip:9999@127.0.0.1:40600>
    18-Nov-2013 11:54:03.640	[CM503007]: Call(C:8): Extn:1004 has joined, contact <sip:1004@10.11.226.102:5060>
    18-Nov-2013 11:54:03.640	~Target=Ext:Ext.9999
    18-Nov-2013 11:54:03.640	Session 402 of leg L:8.1[Extn] is connected
    18-Nov-2013 11:54:03.640	L:8.1[Extn] got Connected.UAS Send 200/INVITE from 0.0.0.0:0 tid=-d2e4ff62 Call-ID=16f147a-12a53b91@10.11.226.102:
    			SIP/2.0 200 OK
    			Via: SIP/2.0/UDP 10.11.226.102:5060;branch=z9hG4bK-d2e4ff62
    			CSeq: 102 INVITE
    			Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
    			Content-Type: application/sdp
    			Supported: replaces
    			User-Agent: 3CXPhoneSystem 12.0.32816.397 (32731)
    			Content-Length: 299
    			v=0
    			o=3cxPS 87929389056 531619643393 IN IP4 10.11.226.247
    			s=3cxPS Audio call
    			c=IN IP4 10.11.226.247
    			t=0 0
    			m=audio 7028 RTP/AVP 0 8 9 18 101
    			a=rtpmap:0 PCMU/8000
    			a=rtpmap:8 PCMA/8000
    			a=rtpmap:9 G722/8000
    			a=rtpmap:18 G729/8000
    			a=rtpmap:101 telephone-event/8000
    			a=fmtp:101 0-15
    			a=sendrecv
    18-Nov-2013 11:54:03.640	Connected(UAS) from "Claudia"<sip:1004@10.11.226.247>;tag=3b77e766512a595o0 to "Voice Mail"<sip:9999@10.11.226.247>;tag=65727d29
    18-Nov-2013 11:54:03.640	L:8.1[Extn] Sending: OnSendResp Send 200/INVITE from 0.0.0.0:0 tid=-d2e4ff62 Call-ID=16f147a-12a53b91@10.11.226.102:
    			SIP/2.0 200 OK
    			CSeq: 102 INVITE
    			Supported: replaces
    			Content-Length: 299
    			v=0
    			s=3cxPS Audio call
    			t=0 0
    			a=fmtp:101 0-15
    			a=sendrecv
    18-Nov-2013 11:54:03.640	SendMsg from "Voice Mail"<sip:9999@10.11.226.247>;tag=65727d29 to "Claudia"<sip:1004@10.11.226.247>;tag=3b77e766512a595o0
    18-Nov-2013 11:54:03.636	L:8.1[Extn]: Terminating targets, reason: SIP ;cause=200 ;text="Call completed elsewhere"
    18-Nov-2013 11:54:03.636	~Route=Dev:sip:9999@127.0.0.1:40600;rinstance=9a20cb43be6bdf2c
    18-Nov-2013 11:54:03.636	L:8.2[VMail] has joined to L:8.1[Extn]
    18-Nov-2013 11:54:03.636	Session 405 of leg L:8.2[VMail] is connected
    18-Nov-2013 11:54:03.636	L:8.2[VMail] got Connected.UAC Recv 200/INVITE from 127.0.0.1:40600 tid=9443e234f55b8a49 Call-ID=YjM5YmI3ZjRhNWY5YTRmZTM3NzA1NTViMjY5NDMwYzQ.:
    			SIP/2.0 200 OK
    			Via: SIP/2.0/UDP 127.0.0.1:5060;branch=z9hG4bK-d8754z-9443e234f55b8a49-1---d8754z-;rport=5060
    			To: <sip:9999@127.0.0.1:5060>;tag=9e4dfc5f
    			From: "Claudia"<sip:1004@127.0.0.1:5060>;tag=ca34d518
    			CSeq: 1 INVITE
    			Supported: replaces
    			Content-Length: 336
    			v=0
    			o=3cxVCE 390941460 194976930 IN IP4 127.0.0.1
    			s=3cxVCE Audio Call
    			c=IN IP4 127.0.0.1
    			t=0 0
    			m=audio 40624 RTP/AVP 0 8 3 13 9 110 99 101
    			a=rtpmap:3 GSM/8000
    			a=rtpmap:13 CN/8000
    			a=rtpmap:110 iLBC/8000
    			a=rtpmap:99 SPEEX/8000
    18-Nov-2013 11:54:03.636	Connected(UAC) from <sip:9999@127.0.0.1:5060>;tag=9e4dfc5f to "Claudia"<sip:1004@127.0.0.1:5060>;tag=ca34d518
    18-Nov-2013 11:54:03.636	Remote SDP is set for leg L:8.2[VMail]
    18-Nov-2013 11:54:03.636	NAT/ALG check:L:8.2[VMail] RESPONSE 200 on 'INVITE' - basic check passed. No information for extended checks
    18-Nov-2013 11:54:03.636	Answer SDP arrived on Leg L:8.2[VMail];
    OnAnswer Recv 200/INVITE from 127.0.0.1:40600 tid=9443e234f55b8a49 Call-ID=YjM5YmI3ZjRhNWY5YTRmZTM3NzA1NTViMjY5NDMwYzQ.:
    			SIP/2.0 200 OK
    			CSeq: 1 INVITE
    			Supported: replaces
    			Content-Length: 336
    			v=0
    			s=3cxVCE Audio Call
    			c=IN IP4 127.0.0.1
    			t=0 0
    			a=rtpmap:3 GSM/8000
    			a=rtpmap:13 CN/8000
    18-Nov-2013 11:54:03.636	L:8.2[VMail] Sending: OnSendReq Send Req ACK from 0.0.0.0:0 tid=a849cd26ea787425 Call-ID=YjM5YmI3ZjRhNWY5YTRmZTM3NzA1NTViMjY5NDMwYzQ.:
    			ACK sip:9999@127.0.0.1:40600;rinstance=9a20cb43be6bdf2c SIP/2.0
    			Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-a849cd26ea787425-1---d8754z-;rport
    			Max-Forwards: 70
    			CSeq: 1 ACK
    			Content-Length: 0
    18-Nov-2013 11:54:03.636	SendMsg from "Claudia"<sip:1004@127.0.0.1:5060>;tag=ca34d518 to <sip:9999@127.0.0.1:5060>;tag=9e4dfc5f
    18-Nov-2013 11:54:03.636	L:8.1[Extn] Sending: OnSendResp Send 180/INVITE from 0.0.0.0:0 tid=-d2e4ff62 Call-ID=16f147a-12a53b91@10.11.226.102:
    			SIP/2.0 180 Ringing
    			CSeq: 102 INVITE
    			Content-Length: 0
    18-Nov-2013 11:54:03.636	SendMsg from "Voice Mail"<sip:9999@10.11.226.247>;tag=65727d29 to "Claudia"<sip:1004@10.11.226.247>;tag=3b77e766512a595o0
    18-Nov-2013 11:54:03.636	Provisional response arrived for session 405 of Leg L:8.2[VMail]
    18-Nov-2013 11:54:03.636	L:8.2[VMail] got Provisional Recv 180/INVITE from 127.0.0.1:40600 tid=9443e234f55b8a49 Call-ID=YjM5YmI3ZjRhNWY5YTRmZTM3NzA1NTViMjY5NDMwYzQ.:
    			SIP/2.0 180 Ringing
    			CSeq: 1 INVITE
    			Content-Length: 0
    18-Nov-2013 11:54:03.636	Provisional(180) from <sip:9999@127.0.0.1:5060>;tag=9e4dfc5f to "Claudia"<sip:1004@127.0.0.1:5060>;tag=ca34d518
    18-Nov-2013 11:54:03.635	[CM505001]: Endpoint VMail:9999: Device info: Device Identified: [Man: 3CX Ltd.;Mod: Voice Mail Menu;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Voice Mail Menu] PBX contact: [sip:9999@127.0.0.1:5060]
    18-Nov-2013 11:54:03.635	[CM503002]: Call(C:8): Alerting VMail:9999 by contact <sip:9999@127.0.0.1:40600>
    18-Nov-2013 11:54:03.633	UacSession 405 has formed leg L:8.2[VMail]
    18-Nov-2013 11:54:03.633	Answer from <sip:9999@127.0.0.1:5060>;tag=9e4dfc5f to "Claudia"<sip:1004@127.0.0.1:5060>;tag=ca34d518
    18-Nov-2013 11:54:03.485	[CM503025]: Call(C:8): Calling T:VMail:9999@[Dev:sip:9999@127.0.0.1:40600;rinstance=9a20cb43be6bdf2c] for L:8.1[Extn]
    18-Nov-2013 11:54:03.485	Route to L:8.2[VMail] sends Invite-OUT Send Req INVITE from 0.0.0.0:0 tid=34714c256f27d158 Call-ID=YjM5YmI3ZjRhNWY5YTRmZTM3NzA1NTViMjY5NDMwYzQ.:
    			INVITE sip:9999@127.0.0.1:40600;rinstance=9a20cb43be6bdf2c SIP/2.0
    			Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-34714c256f27d158-1---d8754z-;rport
    			Max-Forwards: 70
    			CSeq: 1 INVITE
    			Supported: replaces
    			Content-Length: 397
    			v=0
    			o=3cxPS 90496303104 264778022913 IN IP4 127.0.0.1
    			s=3cxPS Audio call
    			c=IN IP4 127.0.0.1
    			t=0 0
    			m=audio 7030 RTP/AVP 0 8 3 13 9 18 110 99 101
    			a=rtpmap:3 GSM/8000
    			a=rtpmap:13 CN/8000
    			a=fmtp:18 annexb=no
    			a=sendrecv
    18-Nov-2013 11:54:03.481	Outbound URI is used: sip:9999@127.0.0.1:40600;rinstance=9a20cb43be6bdf2c
    18-Nov-2013 11:54:03.481	SLA is globally disabled
    18-Nov-2013 11:54:03.481	Added leg L:8.2[VMail]
    18-Nov-2013 11:54:03.438	[Flow] Call(C:8): making call from L:8.1[Extn] to T:VMail:9999@[Dev:sip:9999@127.0.0.1:40600;rinstance=9a20cb43be6bdf2c]
    18-Nov-2013 11:54:03.438	[CM503027]: Call(C:8): From: Extn:1004 ("Claudia" <sip:1004@10.11.226.247:5060>)  to  T:VMail:9999@[Dev:sip:9999@127.0.0.1:40600;rinstance=9a20cb43be6bdf2c]
    18-Nov-2013 11:54:03.438	[CM503004]: Call(C:8): Route 1: from L:8.1[Extn] to T:VMail:9999@[Dev:sip:9999@127.0.0.1:40600;rinstance=9a20cb43be6bdf2c]
    18-Nov-2013 11:54:03.438	[Flow] Endpoint VMail:9999 has no forwarding rule on reason 'All calls'
    18-Nov-2013 11:54:03.438	[Flow] Call(C:8): has built target endpoint: VMail:9999 for call from L:8.1[Extn]
    18-Nov-2013 11:54:03.438	[Flow] Target endpoint for 9999 is VMail:9999
    18-Nov-2013 11:54:03.438	[Flow] Building target endpoint to 9999 from "Claudia" <sip:1004@10.11.226.247:5060>
    18-Nov-2013 11:54:03.438	[CM503010]: Call(C:8): Making route(s) from Extn:1004 to <sip:9999@10.11.226.247:5060>
    18-Nov-2013 11:54:03.438	Remote SDP is set for leg L:8.1[Extn]
    18-Nov-2013 11:54:03.438	OnOffer from "Claudia"<sip:1004@10.11.226.247>;tag=3b77e766512a595o0
    18-Nov-2013 11:54:03.438	[CM505001]: Endpoint Extn:1004: Device info: Device Identified: [Man: Cisco;Mod: SPA Series;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, no-recvonly] UserAgent: [Cisco/SPA514G-7.5.5] PBX contact: [sip:1004@10.11.226.247:5060]
    18-Nov-2013 11:54:03.435	Inbound DID: ''; Phonebook Name: ''
    18-Nov-2013 11:54:03.435	[CM500002]: Call(C:8): Info on incoming INVITE from Extn:1004:
    			Invite-IN Recv Req INVITE from 10.11.226.102:5060 tid=-d2e4ff62 Call-ID=16f147a-12a53b91@10.11.226.102:
    			INVITE sip:9999@10.11.226.247:5060 SIP/2.0
    			Max-Forwards: 70
    			CSeq: 102 INVITE
    			Expires: 240
    			Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER, UPDATE
    			Supported: replaces
    			Content-Length: 401
    			v=0
    			o=- 35496772 35496772 IN IP4 10.11.226.102
    			s=-
    			c=IN IP4 10.11.226.102
    			t=0 0
    			m=audio 16500 RTP/AVP 0 8 9 2 18 96 97 98 101
    			a=rtpmap:2 G726-32/8000
    			a=rtpmap:18 G729a/8000
    			a=rtpmap:96 G726-40/8000
    			a=rtpmap:97 G726-24/8000
    			a=rtpmap:98 G726-16/8000
    			a=fmtp:101 0-15
    			a=ptime:20
    			a=sendrecv
    18-Nov-2013 11:54:03.435	[CM503001]: Call(C:8): Incoming call from Extn:1004 to "Voice Mail" <sip:9999@10.11.226.247:5060>
    18-Nov-2013 11:54:03.433	NAT/ALG check:L:8.1[Extn] REQUEST 'INVITE' - basic check passed. No information for extended checks
    18-Nov-2013 11:54:03.430	NAT/ALG check:L:8.1[Extn] REQUEST 'INVITE' - basic check passed. No information for extended checks
    18-Nov-2013 11:54:03.430	Offer SDP arrived on Leg L:8.1[Extn];
    OnOffer Recv Req INVITE from 10.11.226.102:5060 tid=-d2e4ff62 Call-ID=16f147a-12a53b91@10.11.226.102:
    			Max-Forwards: 70
    			CSeq: 102 INVITE
    			Expires: 240
    			Supported: replaces
    			Content-Length: 401
    			v=0
    			s=-
    			t=0 0
    			a=fmtp:101 0-15
    			a=ptime:20
    			a=sendrecv
    18-Nov-2013 11:54:03.430	Outbound URI is used: sip:1004@10.11.226.102:5060
    18-Nov-2013 11:54:03.430	IncomingCall: C:8 from <sip:1004@10.11.226.247:5060> to <sip:9999@10.11.226.247:5060>
    18-Nov-2013 11:54:03.430	Added leg L:C:8.1[No endpoint yet]
    18-Nov-2013 11:54:03.430	UasSession 402 started
    18-Nov-2013 11:54:03.430	Call from "Claudia"<sip:1004@10.11.226.247>;tag=3b77e766512a595o0 to "Voice Mail"<sip:9999@10.11.226.247>;tag=65727d29
    Logs from when I call voicemail on the first phone and it just rings:
    Code:
    18-Nov-2013 11:58:56.466	Currently active calls [none]
    18-Nov-2013 11:58:24.468	Currently active calls [none]
    18-Nov-2013 11:58:02.885	L:10.2[VMail]: Terminating targets, reason:
    18-Nov-2013 11:58:02.885	Leg L:10.2[VMail] is terminated: Cause: BYE from PBX
    18-Nov-2013 11:58:02.884	Terminated from <sip:9999@127.0.0.1:5060>;tag=252a651a to "Tyler Slocum"<sip:1051@127.0.0.1:5060>;tag=c2672557; reason: LocalBye
    18-Nov-2013 11:58:02.884	L:10.2[VMail] Sending: OnSendReq Send Req BYE from 0.0.0.0:0 tid=0f1e53314b178753 Call-ID=MjRlZDI0MDAxNTZiYjJhY2M5NGExOGZjOTMzYmRkNmU.:
    			BYE sip:9999@127.0.0.1:40600;rinstance=9a20cb43be6bdf2c SIP/2.0
    			Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-0f1e53314b178753-1---d8754z-;rport
    			Max-Forwards: 70
    			Contact: <sip:1051@127.0.0.1:5060>
    			To: <sip:9999@127.0.0.1:5060>;tag=252a651a
    			From: "Tyler Slocum"<sip:1051@127.0.0.1:5060>;tag=c2672557
    			Call-ID: MjRlZDI0MDAxNTZiYjJhY2M5NGExOGZjOTMzYmRkNmU.
    			CSeq: 2 BYE
    			Content-Length: 0
    18-Nov-2013 11:58:02.884	SendMsg from "Tyler Slocum"<sip:1051@127.0.0.1:5060>;tag=c2672557 to <sip:9999@127.0.0.1:5060>;tag=252a651a
    18-Nov-2013 11:58:02.884	[CM503008]: Call(C:10): Call is terminated
    18-Nov-2013 11:58:02.884	L:10.2[VMail]: Terminating targets, reason: SIP ;cause=200 ;text="Call terminated on user request"
    18-Nov-2013 11:58:02.882	Blocking refers for the Call(C:10)
    18-Nov-2013 11:58:02.882	Call(C:10) is terminated
    18-Nov-2013 11:58:02.882	L:10.1[Extn]: Terminating targets, reason: SIP ;cause=200 ;text="User hangup"
    18-Nov-2013 11:58:02.882	Leg L:10.1[Extn] is terminated: Cause: BYE from 10.11.226.101:5060
    18-Nov-2013 11:58:02.880	L:10.1[Extn] got Terminated Recv Req BYE from 10.11.226.101:5060 tid=-7475368b Call-ID=f5f8a15c-142c1b64@10.11.226.101:
    			BYE sip:9999@10.11.226.247:5060 SIP/2.0
    			Via: SIP/2.0/UDP 10.11.226.101:5060;branch=z9hG4bK-7475368b
    			Max-Forwards: 70
    			To: "Voice Mail"<sip:9999@10.11.226.247>;tag=1e07f311
    			From: "Tyler Slocum"<sip:1051@10.11.226.247>;tag=b75ba8fc68bb844o0
    			Call-ID: f5f8a15c-142c1b64@10.11.226.101
    			CSeq: 103 BYE
    			Proxy-Authorization: Digest username="1051",realm="3CXPhoneSystem",nonce="414d535c089ad80a13:d11e73718094d6a9eb72030e2f58a2bb",uri="sip:9999@10.11.226.247:5060",algorithm=MD5,response="f824877d9a86bd1275e9a995e074eb6d"
    			Content-Length: 0
    18-Nov-2013 11:58:02.880	Terminated from "Tyler Slocum"<sip:1051@10.11.226.247>;tag=b75ba8fc68bb844o0 to "Voice Mail"<sip:9999@10.11.226.247>;tag=1e07f311; reason: RemoteBye
    18-Nov-2013 11:58:02.880	L:10.1[Extn] Sending: OnSendResp Send 200/BYE from 0.0.0.0:0 tid=-7475368b Call-ID=f5f8a15c-142c1b64@10.11.226.101:
    			SIP/2.0 200 OK
    			CSeq: 103 BYE
    			Content-Length: 0
    18-Nov-2013 11:58:02.880	SendMsg from "Voice Mail"<sip:9999@10.11.226.247>;tag=1e07f311 to "Tyler Slocum"<sip:1051@10.11.226.247>;tag=b75ba8fc68bb844o0
    18-Nov-2013 11:57:52.470	Currently active calls - 1: [10]
    18-Nov-2013 11:57:47.406	Session 490 of leg L:10.1[Extn] is confirmed
    18-Nov-2013 11:57:47.406	L:10.1[Extn] got Confirmed Recv Req ACK from 10.11.226.101:5060 tid=-4d71605f Call-ID=f5f8a15c-142c1b64@10.11.226.101:
    			Via: SIP/2.0/UDP 10.11.226.101:5060;branch=z9hG4bK-4d71605f
    			Max-Forwards: 70
    			Contact: "Tyler Slocum"<sip:1051@10.11.226.101:5060>
    			CSeq: 102 ACK
    			Proxy-Authorization: Digest username="1051",realm="3CXPhoneSystem",nonce="414d535c089ad80a13:d11e73718094d6a9eb72030e2f58a2bb",uri="sip:9999@10.11.226.247:5060",algorithm=MD5,response="15dcaae08f5ecb85b8d51fb559186d56"
    			Content-Length: 0
    18-Nov-2013 11:57:47.406	ConnCfmd from "Tyler Slocum"<sip:1051@10.11.226.247>;tag=b75ba8fc68bb844o0 to "Voice Mail"<sip:9999@10.11.226.247>;tag=1e07f311
    18-Nov-2013 11:57:47.062	[CM503007]: Call(C:10): VMail:9999 has joined, contact <sip:9999@127.0.0.1:40600>
    18-Nov-2013 11:57:47.059	[CM503007]: Call(C:10): Extn:1051 has joined, contact <sip:1051@10.11.226.101:5060>
    18-Nov-2013 11:57:47.059	~Target=Ext:Ext.9999
    18-Nov-2013 11:57:47.059	Session 490 of leg L:10.1[Extn] is connected
    18-Nov-2013 11:57:47.059	L:10.1[Extn] got Connected.UAS Send 200/INVITE from 0.0.0.0:0 tid=-7fdc6860 Call-ID=f5f8a15c-142c1b64@10.11.226.101:
    			SIP/2.0 200 OK
    			Via: SIP/2.0/UDP 10.11.226.101:5060;branch=z9hG4bK-7fdc6860
    			CSeq: 102 INVITE
    			Supported: replaces
    			Content-Length: 300
    			v=0
    			o=3cxPS 234864246784 312676974593 IN IP4 10.11.226.247
    			s=3cxPS Audio call
    			t=0 0
    			m=audio 7036 RTP/AVP 0 8 9 18 101
    			a=fmtp:101 0-15
    			a=sendrecv
    18-Nov-2013 11:57:47.059	Connected(UAS) from "Tyler Slocum"<sip:1051@10.11.226.247>;tag=b75ba8fc68bb844o0 to "Voice Mail"<sip:9999@10.11.226.247>;tag=1e07f311
    18-Nov-2013 11:57:47.059	L:10.1[Extn] Sending: OnSendResp Send 200/INVITE from 0.0.0.0:0 tid=-7fdc6860 Call-ID=f5f8a15c-142c1b64@10.11.226.101:
    			SIP/2.0 200 OK
    			CSeq: 102 INVITE
    			Supported: replaces
    			Content-Length: 300
    			v=0
    			s=3cxPS Audio call
    			t=0 0
    			a=fmtp:101 0-15
    			a=sendrecv
    18-Nov-2013 11:57:47.059	SendMsg from "Voice Mail"<sip:9999@10.11.226.247>;tag=1e07f311 to "Tyler Slocum"<sip:1051@10.11.226.247>;tag=b75ba8fc68bb844o0
    18-Nov-2013 11:57:47.056	L:10.1[Extn]: Terminating targets, reason: SIP ;cause=200 ;text="Call completed elsewhere"
    18-Nov-2013 11:57:47.056	~Route=Dev:sip:9999@127.0.0.1:40600;rinstance=9a20cb43be6bdf2c
    18-Nov-2013 11:57:47.056	L:10.2[VMail] has joined to L:10.1[Extn]
    18-Nov-2013 11:57:47.056	Session 493 of leg L:10.2[VMail] is connected
    18-Nov-2013 11:57:47.056	L:10.2[VMail] got Connected.UAC Recv 200/INVITE from 127.0.0.1:40600 tid=a633ab12e9476b70 Call-ID=MjRlZDI0MDAxNTZiYjJhY2M5NGExOGZjOTMzYmRkNmU.:
    			SIP/2.0 200 OK
    			Via: SIP/2.0/UDP 127.0.0.1:5060;branch=z9hG4bK-d8754z-a633ab12e9476b70-1---d8754z-;rport=5060
    			CSeq: 1 INVITE
    			Supported: replaces
    			Content-Length: 336
    			v=0
    			o=3cxVCE 351931260 207062685 IN IP4 127.0.0.1
    			s=3cxVCE Audio Call
    			c=IN IP4 127.0.0.1
    			t=0 0
    			m=audio 40628 RTP/AVP 0 8 3 13 9 110 99 101
    			a=rtpmap:3 GSM/8000
    			a=rtpmap:13 CN/8000
    18-Nov-2013 11:57:47.056	Connected(UAC) from <sip:9999@127.0.0.1:5060>;tag=252a651a to "Tyler Slocum"<sip:1051@127.0.0.1:5060>;tag=c2672557
    18-Nov-2013 11:57:47.056	Remote SDP is set for leg L:10.2[VMail]
    18-Nov-2013 11:57:47.056	NAT/ALG check:L:10.2[VMail] RESPONSE 200 on 'INVITE' - basic check passed. No information for extended checks
    18-Nov-2013 11:57:47.056	Answer SDP arrived on Leg L:10.2[VMail];
    OnAnswer Recv 200/INVITE from 127.0.0.1:40600 tid=a633ab12e9476b70 Call-ID=MjRlZDI0MDAxNTZiYjJhY2M5NGExOGZjOTMzYmRkNmU.:
    			SIP/2.0 200 OK
    			CSeq: 1 INVITE
    			Supported: replaces
    			Content-Length: 336
    			v=0
    			s=3cxVCE Audio Call
    			c=IN IP4 127.0.0.1
    			t=0 0
    			a=rtpmap:3 GSM/8000
    			a=rtpmap:13 CN/8000
    18-Nov-2013 11:57:47.056	L:10.2[VMail] Sending: OnSendReq Send Req ACK from 0.0.0.0:0 tid=7057df2f84797e0b Call-ID=MjRlZDI0MDAxNTZiYjJhY2M5NGExOGZjOTMzYmRkNmU.:
    			Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-7057df2f84797e0b-1---d8754z-;rport
    			Max-Forwards: 70
    			CSeq: 1 ACK
    			Content-Length: 0
    18-Nov-2013 11:57:47.056	SendMsg from "Tyler Slocum"<sip:1051@127.0.0.1:5060>;tag=c2672557 to <sip:9999@127.0.0.1:5060>;tag=252a651a
    18-Nov-2013 11:57:47.055	L:10.1[Extn] Sending: OnSendResp Send 180/INVITE from 0.0.0.0:0 tid=-7fdc6860 Call-ID=f5f8a15c-142c1b64@10.11.226.101:
    			SIP/2.0 180 Ringing
    			CSeq: 102 INVITE
    			Content-Length: 0
    18-Nov-2013 11:57:47.055	SendMsg from "Voice Mail"<sip:9999@10.11.226.247>;tag=1e07f311 to "Tyler Slocum"<sip:1051@10.11.226.247>;tag=b75ba8fc68bb844o0
    18-Nov-2013 11:57:47.055	Provisional response arrived for session 493 of Leg L:10.2[VMail]
    18-Nov-2013 11:57:47.055	L:10.2[VMail] got Provisional Recv 180/INVITE from 127.0.0.1:40600 tid=a633ab12e9476b70 Call-ID=MjRlZDI0MDAxNTZiYjJhY2M5NGExOGZjOTMzYmRkNmU.:
    			SIP/2.0 180 Ringing
    			CSeq: 1 INVITE
    			Content-Length: 0
    18-Nov-2013 11:57:47.055	Provisional(180) from <sip:9999@127.0.0.1:5060>;tag=252a651a to "Tyler Slocum"<sip:1051@127.0.0.1:5060>;tag=c2672557
    18-Nov-2013 11:57:47.055	[CM505001]: Endpoint VMail:9999: Device info: Device Identified: [Man: 3CX Ltd.;Mod: Voice Mail Menu;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Voice Mail Menu] PBX contact: [sip:9999@127.0.0.1:5060]
    18-Nov-2013 11:57:47.055	[CM503002]: Call(C:10): Alerting VMail:9999 by contact <sip:9999@127.0.0.1:40600>
    18-Nov-2013 11:57:47.053	UacSession 493 has formed leg L:10.2[VMail]
    18-Nov-2013 11:57:47.053	Answer from <sip:9999@127.0.0.1:5060>;tag=252a651a to "Tyler Slocum"<sip:1051@127.0.0.1:5060>;tag=c2672557
    18-Nov-2013 11:57:46.905	[CM503025]: Call(C:10): Calling T:VMail:9999@[Dev:sip:9999@127.0.0.1:40600;rinstance=9a20cb43be6bdf2c] for L:10.1[Extn]
    18-Nov-2013 11:57:46.905	Route to L:10.2[VMail] sends Invite-OUT Send Req INVITE from 0.0.0.0:0 tid=26199a00e30fcd18 Call-ID=MjRlZDI0MDAxNTZiYjJhY2M5NGExOGZjOTMzYmRkNmU.:
    			Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-26199a00e30fcd18-1---d8754z-;rport
    			Max-Forwards: 70
    			CSeq: 1 INVITE
    			Supported: replaces
    			Content-Length: 397
    			v=0
    			o=3cxPS 237431160832 45852131329 IN IP4 127.0.0.1
    			s=3cxPS Audio call
    			c=IN IP4 127.0.0.1
    			t=0 0
    			m=audio 7038 RTP/AVP 0 8 3 13 9 18 110 99 101
    			a=rtpmap:3 GSM/8000
    			a=rtpmap:13 CN/8000
    			a=fmtp:18 annexb=no
    			a=sendrecv
    18-Nov-2013 11:57:46.901	Outbound URI is used: sip:9999@127.0.0.1:40600;rinstance=9a20cb43be6bdf2c
    18-Nov-2013 11:57:46.901	SLA is globally disabled
    18-Nov-2013 11:57:46.901	Added leg L:10.2[VMail]
    18-Nov-2013 11:57:46.860	[Flow] Call(C:10): making call from L:10.1[Extn] to T:VMail:9999@[Dev:sip:9999@127.0.0.1:40600;rinstance=9a20cb43be6bdf2c]
    18-Nov-2013 11:57:46.860	[CM503027]: Call(C:10): From: Extn:1051 ("Tyler Slocum" <sip:1051@10.11.226.247:5060>)  to  T:VMail:9999@[Dev:sip:9999@127.0.0.1:40600;rinstance=9a20cb43be6bdf2c]
    18-Nov-2013 11:57:46.860	[CM503004]: Call(C:10): Route 1: from L:10.1[Extn] to T:VMail:9999@[Dev:sip:9999@127.0.0.1:40600;rinstance=9a20cb43be6bdf2c]
    18-Nov-2013 11:57:46.860	[Flow] Endpoint VMail:9999 has no forwarding rule on reason 'All calls'
    18-Nov-2013 11:57:46.860	[Flow] Call(C:10): has built target endpoint: VMail:9999 for call from L:10.1[Extn]
    18-Nov-2013 11:57:46.860	[Flow] Target endpoint for 9999 is VMail:9999
    18-Nov-2013 11:57:46.860	[Flow] Building target endpoint to 9999 from "Tyler Slocum" <sip:1051@10.11.226.247:5060>
    18-Nov-2013 11:57:46.860	[CM503010]: Call(C:10): Making route(s) from Extn:1051 to <sip:9999@10.11.226.247:5060>
    18-Nov-2013 11:57:46.860	Remote SDP is set for leg L:10.1[Extn]
    18-Nov-2013 11:57:46.860	OnOffer from "Tyler Slocum"<sip:1051@10.11.226.247>;tag=b75ba8fc68bb844o0
    18-Nov-2013 11:57:46.860	[CM505001]: Endpoint Extn:1051: Device info: Device Identified: [Man: Cisco;Mod: SPA Series;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, no-recvonly] UserAgent: [Cisco/SPA514G-7.5.5] PBX contact: [sip:1051@10.11.226.247:5060]
    18-Nov-2013 11:57:46.856	Inbound DID: ''; Phonebook Name: ''
    18-Nov-2013 11:57:46.856	[CM500002]: Call(C:10): Info on incoming INVITE from Extn:1051:
    			Invite-IN Recv Req INVITE from 10.11.226.101:5060 tid=-7fdc6860 Call-ID=f5f8a15c-142c1b64@10.11.226.101:
    			Max-Forwards: 70
    			CSeq: 102 INVITE
    			Expires: 240
    			Supported: replaces
    			Content-Length: 401
    			v=0
    			o=- 33847953 33847953 IN IP4 10.11.226.101
    			s=-
    			c=IN IP4 10.11.226.101
    			t=0 0
    			m=audio 16434 RTP/AVP 0 8 9 2 18 96 97 98 101
    			a=fmtp:101 0-15
    			a=ptime:20
    			a=sendrecv
    18-Nov-2013 11:57:46.856	[CM503001]: Call(C:10): Incoming call from Extn:1051 to "Voice Mail" <sip:9999@10.11.226.247:5060>
    18-Nov-2013 11:57:46.854	NAT/ALG check:L:10.1[Extn] REQUEST 'INVITE' - basic check passed. No information for extended checks
    18-Nov-2013 11:57:46.852	Outbound URI is used: sip:1051@10.11.226.101:5060
    18-Nov-2013 11:57:46.852	IncomingCall: C:10 from <sip:1051@10.11.226.247:5060> to <sip:9999@10.11.226.247:5060>
    18-Nov-2013 11:57:46.852	Added leg L:C:10.1[No endpoint yet]
    18-Nov-2013 11:57:46.851	UasSession 490 started
    18-Nov-2013 11:57:46.851	Call from "Tyler Slocum"<sip:1051@10.11.226.247>;tag=b75ba8fc68bb844o0 to "Voice Mail"<sip:9999@10.11.226.247>;tag=1e07f311
    18-Nov-2013 11:57:20.472	Currently active calls [none]
  6. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Open internet browser on your server and type following text in "address" bar:
    http://127.0.0.1:5000/ivr
    What is the answer "browser" has received?
  7. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    15
    HTTP 400 Bad Request - Invalid Hostname
    Is that the problem? Should it be the server IP, 10.11.226.247?
  8. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    15
    Could someone please help me out on this?
  9. lneblett
    Sep 7, 2010
    2,086
    65
    I am not exactly sure where SY was going with his question, but you might do the following -
    1. They just released a new SP, you should try updating and see what happens.
    2. Once the system has restarted, ensure that all the system services are started and that all system extensions are registered (green).
    3. Turn off the Windows firewall and test.
  10. leejor
    11,105
    329
    If I do that, I get..
    Greetings audio set to
    So something on your network, or in your settings(most likely), obviously isn't correct(port 5000 in use elsewhere or blocked?), and the problem may be left from before you changed your IP. Have you done a backup (or a couple, just to be sure) , then un-installed and re-installed 3CX?
    Before you apply the back-up, you might want to manually configure one extension and test the voicemail to be sure that it isn't a hardware issue (I doubt it is, but...)
    Have you tried installing 3CX on another machine, as a test?
