This is a great product!
Discussion in '3CX Phone System - General' started by mike_at_software, Jan 8, 2007.
  1. mike_at_software
    Jan 6, 2007
    33
    Well done to all of your team for such great development work.
    I struggled for two weeks with two competing products, which never fully worked, before discovering your software, which was installed and operating in less than one hour.
    Your approach to winning customers is a key differentiator to the other products I tried, and the elements which I think make your offering so compelling are:
    1. Ease of installation
    2. A clear, comprehensive and accurate manual
    3. An attractive UI
    4. Competent and accessible support
    5. Software that just works!
    I know these seem like obvious points, but you
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,992
    308
    Thanks!!
    Hi Mike,
    Thanks for the great feedback!
    its great to hear that our product is appreciated! As a note we are currently working on a new version, which should be much much better then the current version. i look forward to your feedback on it!
