Thomson ST2030 with 3CX
Discussion in '3CX Phone System - General' started by carmico, Oct 11, 2007.
  1. carmico
    Oct 11, 2007
    23
    i want a configuration guide or help for the sip phone "Thomson ST2030" .
    i'm newbie in voip.
    thanks!
  2. LORD ORION
    Jul 23, 2007
    39
    http://www.voip-info.org/wiki/view/ST2030+Configuration+HowTo
    Pretty straight forward.
    ST2030 User Account -> 3CX Authentication during extension creation
    Authentication ID = ID
    Password = Password
  3. carmico
    Oct 11, 2007
    23
    ok, thanks
    that configuration guide works fine with 3cx ?
    the thomson st2030 is fully compatible with 3cx ? i mean the features.
    thanks.
  4. LORD ORION
    Jul 23, 2007
    39
    Unfortunately, since it doesn't have a how-to guide on 3CX.com, I don't think it is supported.
    The only way to know is to try it, and if there are any weird things happening, post here.
    Most sip compliant devices should work with basic functionalty, but because SIP allows for custom functionality, proprietary device functions of specific vendors may not work.
