Tiles on Dashboard and Settings Page
Discussion in 'Ideas' started by ucs1, Jul 6, 2016.
  1. ucs1
    Jun 21, 2013
    42
    Firstly, it was nice to see the Tiles arranged in alphabetical order in the settings menu.
    I would like to have the ability to customize what 6 tiles are displayed on the Main Dashboard, maybe this could be done as a selection from the settings menu.
    Additional to this, is it possible we can add the 6 tiles from the dashboard to the settings page also. I know it will only take a day or two to get used to, but logically....
    If you wanted to check an IP Blacklist, where would I look?
    Settings or Security.
    The updates also have a nice notification icon at the top of the screen although having a tile in the settings would still be worthwhile.
