Time Conditions/Time Based rules in 3CX
Discussion in 'Ideas' started by 3CX-IDEAS, Sep 28, 2015.
Time Conditions/Time Based rules in 3CX 5 5 9votes
5/5, 9 votes
  1. 3CX-IDEAS
    Sep 28, 2015
    10
    24
    One big problem we are facing when migrating to 3CX is the lack of time conditions, or time based rules.
    We need the ability to configure different ivr prompts for different days of week or specified hours of day.
    For example to play one prompt on Monday, another on Tuesday and etc. As well as, to play different message during specified hours.
  2. alhambra-eidos
    Mar 31, 2014
    6
    21
    This is an important gap of 3CX.
    Consider one 3CX operating in various countries (or regions). Currently, you can define 24th Dec as holiday for all countries on Incoming calls, but can´t define domestic holidays for each country.
    Different holiday calendars (or time based) should be applied by DID (at Incoming Rules Level), in order to give a “holiday prompt” for a specific country, while other DID for other countries are in service.
    This will be a great leap.
    Please consider it!
    Regards
  3. solutionsit
    Nov 25, 2014
    62
    5
    Timed module
    We ran into a situation where a option in our IVR needs to be timed. Meaning during work hours the destination needs to go to a ring group, and after work hours it needs to go a IVR or voicemail box.
    So ideally this would be a different module like digital receptions, ringgroup... and just be able to put a timed action in the call flow.
  4. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    305
    Re: Timed module
    Perhaps using a Dummy Extension would help?
  5. djahugen
    May 4, 2016
    Re: Timed module
    how should one set up a dummy extension to solve this?
  6. leejor
    11,126
    330
    Re: Timed module
    Create an extension that all the calls initially route to. Use the forwarding options (of that extension), based on office hours, to send call to the required destination.
  7. PatrickTodd
    Jan 12, 2016
    40
    6
    Re: Timed module
    A non-hacky solution goes a long way towards customer satisfaction.
  8. leejor
    11,126
    330
    Agreed. That is why newer versions are released, with additional features.
    craigreilly likes this.
  9. Maxime Clermont
    Mar 12, 2018
    8
    I'm very sorry to revive this old thread but I cannot believe that this feature has not been implemented yet. This is a very basic module to code and implement. As a 3CX parter, I have to reconsider using 3CX for our customers because in some cases, they require time conditions since they deal with countries with different time zones.
    It has been two years, no signs of time conditions yet. I don't want to use a program, I want to use the web-based interface.
    Chrischevy80 likes this.
  10. voiptoys
    voiptoys Active Member
    Feb 13, 2013
    893
    154
    We built a "prompt scheduler" application to automatically change prompts based on time of day and day of week. Perhaps we could discuss in detail what you want and modify / enhance our tool to more fully meet your needs. I don't think this is a good candidate for a Call Flow Designer application simply because we don't want to funnel all the calls to a central extension for routing purposes, although I suppose you could. Rather I think a service that monitors all the conditions and controls office hours, and prompts is going to be more flexible. If you need help, we can build exactly what you need. The only other alternative is to wait.
  11. Maxime Clermont
    Mar 12, 2018
    8
    Sorry but I'm not looking for a third-party solution. I'm looking for something that works out-of-the-box.
  12. lexcom
    Jan 29, 2010
    There is no time zone for Saskatchewan -6:00 in 3CX. Saskatchewan (Canada) never changes the time but there is no setting for this in the software. Microsoft servers have added it over 10 years ago and Ideally if we select use the global time from the server in this time setting that would be ideal. For now we need to manually change it twice a year.
    Ifrix Solutions likes this.
  13. timmbo
    timmbo New Member
    Aug 25, 2017
    103
    48
  14. Andy vdG
    Oct 24, 2018
  15. IA76
    Mar 31, 2011
    24
  16. PeterLim
    Jun 29, 2018
    6
    i think 3CX CFD may able to do that.
  17. Chrischevy80
    Oct 1, 2017
    27
  18. Lucky Santiago
    Nov 9, 2017
    6
  19. Wendelspanswick
    Wendelspanswick New Member
    Jan 11, 2016
    154
    That's what we use, we name them Time Of Day (TOD) routing extensions, the Inbound Rule points at the TOD where it rings for 1 second before forwarding to the required location depending on the TOD extensions office hours.
