Time do transfer to voicemail
Discussion in '3CX Phone System - General' started by Daniel Sant Anna, Oct 27, 2017.
  1. Daniel Sant Anna
    Feb 12, 2017
    10
    Hi there,
    I have been trying to find a way to increase the on hold time before reach the voicemail without success. Some tips for that?
    Thanks in advance!
  2. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    220
    Where, in what situation ?
    Probably you need to modify the value for forwarding timeout in extension settings.
    #2 sip.bg, Oct 28, 2017
