Time of recording
Discussion in '3CX Phone System - General' started by RLeao, Jan 29, 2018.
  1. RLeao
    Oct 2, 2017
    6
    What is the limit of recording time in a meeting?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,326
    532
    Hello @RLeao
    Are you referring to WebMeeting or a conference call? There is no time limit for WebMeeting recording and a conference call will be recorded at the extension level until the extension terminates the call
    RLeao likes this.
  3. RLeao
    Oct 2, 2017
    6
    Thank you YiannisH_3CX,
    The doubt was in relation to web meeting and conference call too. I will test and present to the customer.
  4. voiptoys
    voiptoys Active Member
    Feb 13, 2013
    893
    154
    I believe the maximum length of a standard phone call is 3 hours. I suspect that maximum call length of a conference call is the same.
  5. Brian Cross
    Brian Cross New Member
    Jul 26, 2017
    109
    27
    The maxcallduration parameter defaults to 10800 seconds = 3 hours.
  6. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,557
    118
    -Till recently there was no limit to the duration of a WebMeeting's duration and it's recording.
    -Due to technical restrictions and impossibilities we've decided to add a 20 hour max limit for a meeting session's duration and recording duration.
