Solved Time out Spinner
Discussion in '3CX Phone System - General' started by MarPyt, Jan 16, 2018.
  1. MarPyt
    Feb 7, 2015
    12
    Under Extensions, Forwarding Rules, time out spinner is "stuck" at 20 seconds. Adjusting up or down the timer
    yields no results, value stays at 20 seconds. Tried out on server in a cloud as well as local pbx. V 15.5
    Did anyone have come across this problem?
  2. mariosM_3CX
    mariosM_3CX Support Team
    Nov 1, 2017
    406
    40
    Hello @MarPyt
    What about manually writing the value instead of using the up/down arrows. Does this have the same effect. Also, what browser are you using? Try with a different browser and see if you still have the issue.
  3. MarPyt
    Feb 7, 2015
    12
  4. MarPyt
    Feb 7, 2015
    12
    FYI
    On Chrome spinner works. On Explorer put in values manually. On Firefox spinner does not work but manual override does. Annoyance solved and thank you for pointing it out.
  5. mariosM_3CX
    Nov 1, 2017
    406
    40
    Hello @MarPyt
    The supported Browsers are Chrome, EDGE and Firefox. Just make sure that you have the latest updated versions of the above browsers.
