Time ranges instead of Office hours
Discussion in 'Ideas' started by Matt Healey, Nov 30, 2017.
  1. Matt Healey
    Nov 30, 2017
    I'd like to see the ability to specify an arbitrary number of time ranges and groups of time ranges that can be used where appropriate.
    They would all be listed in a single location within the UI which would make changing this very easy as you would go to the time ranges area... edit it... and then that would be set for anywhere that time range was referenced.
    Each entry would have options like the following...
    - Daily
    from and to time
    days valid (Weekdays, Weekends, Monday thru Friday)
    - Weekly
    From Monday thru Friday + Start Time
    To Monday thru Friday + Finish Time
    - Absolute
    From Date + Time
    To Date + Time
    Then on top of that you have groups of time ranges so you can reference them as a single entity within the various config places.
