Time to answer call
Discussion in '3CX Phone System - General' started by BendyMetal, Jan 25, 2008.
  1. BendyMetal
    Oct 8, 2007
    36
    Is there a field in the database anywhere or a way of calculating how long it has taken to answer a call? I can't seem to find a field or way.
  2. huzer1
    Oct 30, 2007
    33
    As far as I know, 3cx doesn't have a feature like that. maybe in your gateway? I'm also assuming that you mean the time from when the phone call comes in to the time someone answers it.
  3. LLangston
    Aug 27, 2007
    57
    There are two places in the 3CX console that you can input values that can affect the length of time for answering...the first one is under Manage Lines > Other Options > Answer After(seconds) input the value here. The second is under Manage Extensions > Destination Unreachable/Forwarding > No Answer After(seconds) input the value here. Both of these settings will affect anwer time length.
  4. BendyMetal
    Oct 8, 2007
    36
    Yes Huzer, that is what I am after. I need a way to find out how long a person was waiting for their call to be answered. If there is no logging done in 3cx then there is no logging.
    Thanks anyway guys
