Time-zone change on V14 SP3
Discussion in '3CX Phone System - General' started by kugla007, Nov 8, 2017.
  1. kugla007
    Sep 5, 2017
    9
    is there a way to change the global timezone settings on V14 SP3?
    https://i.imgur.com/YbHpKAd.png
    When I go under PhoneProvisioning and choose to use the global time zone settings I can see that it is incorrectly set. The server on which 3CX is running has the correct timezone.
